Blank Part numbers in Design Table
Posted: Wed Oct 26, 2022 9:47 am
by gerard
Once upon a time blanks were allowed in Design Tables for Part numbers.
Evidently, now they aren't.
Dunno when this happened.
I've got a fastener library that was created WAY BACK WHEN which has blanks in the Part Numbers.
Now if I make the mistake of editing the design table, SWX reassigns this to $C.
Anyway to force the Part Number to be blank?
Thanks,
g
Re: Blank Part numbers in Design Table
Posted: Wed Oct 26, 2022 10:03 am
by DanPihlaja
gerard wrote: ↑Wed Oct 26, 2022 9:47 am
If I make the mistake of editing the design table, SWX reassigns this to $C.
Thanks,
g
Assuming that you mean that there is a component in which you haven't assigned a part number, then leave the "SW-Part Number" property on each of your components blank. Then it should show up as blank in the BOM.
Or do you mean keeping a row for a missing component?
If that's the case, then:
Posted: Wed Oct 26, 2022 10:19 am
Have you tried hitting the spacebar a time or two in the text box for assigning the part number?
Posted: Wed Oct 26, 2022 10:38 am
by TTevolve
We use file names as part numbers so it's automatic, but in other fields if you want a blank we use a space like Glenn suggested.
Posted: Wed Oct 26, 2022 10:50 am
by gerard
Here's the weird part.
Doing some playing around, this seems to be part specific.
My flat washer part wont let me use a space for the part number, but my lock washer part will.
My head hurts.....
Posted: Wed Oct 26, 2022 11:31 am
by JSculley
2013 by the looks of it:
Thanks,
g
You have to put text of some sort in there. As others have said, a space is one option. Personally, I'd use something more meaningful such as N/A, or what I've done in my hardware design table is put 'UNASSIGNED' since here every piece of hardware is supposed to have a part number. This lets me know which parts haven't been assigned numbers.
Posted: Wed Oct 26, 2022 2:42 pm
by gerard
I'm guessing at this stage is that it's a file issue. Other, similar files, don't do this.
I'll have to figure it out....
Posted: Wed Oct 26, 2022 4:43 pm
Do you have a screenshot? Words are pretty much up to interpretation.
Are we talking part properties or body properties?
Posted: Thu Oct 27, 2022 8:43 am
by gerard
AlexLachance wrote: ↑Wed Oct 26, 2022 4:43 pm
Unfortunately, my SWX machine is on a protected enclave not attached to the innerwebs.
Network cross pollination is verboten...
I'm pretty sure at this stage that it is a buggered up design table in the subject part.
I'll export it and then delete and recreate to see if it alleviates the situation.
thanks
g
Posted: Thu Oct 27, 2022 9:02 am
gerard wrote: ↑Thu Oct 27, 2022 8:43 am
thanks
g
Take a picture with your phone!
Posted: Thu Oct 27, 2022 10:16 am
by gerard
So,
Much ado about nothing. I deleted the excel design table and recreated it with a space in the part number and all is well.
Sorry for the distraction.
Posted: Thu Oct 27, 2022 10:18 am
gerard wrote: ↑Thu Oct 27, 2022 10:16 am
So,
No need to apologize Gerard. At least you found a fix!
