PDM customize RMB menu with sub menus
Discuss SolidWorks PDM
x 601
x 282
I am lookIng for a way to reduce the size oF the RMB menu inside the vault.
I have already moved all our tasks inside a sub menu and I would like to move the vault add-ins in a "add-in" sub folder but I cannot find a way to do it. Any idea?
as reference:
https://www.cati.com/blog/configuring-m ... pdm-users/
x 2443
x 1331
Re: PDM customize RMB menu with sub menus
how many add-ins do you have?!
I haven't touched the right click menu since I messed it all up for the Design group. I opened the setting from the group settings dialog and it was completely blank. Thought, "that's strange, oh well, I'll add the item I came here to add and move on." Well, everyone in the group now had just that one item in the right click menu. Too me a while to rebuild it; I couldn't figure out how to just set back to default. Found out that if a user is in more than one group the settings GUI just throws up its hands and starts carte blanche. It was like biting into a moldy sandwich, so I haven't gone back to that fridge.
Answers: 54
x 7
x 815
mp3-250 wrote: Tue Nov 15, 2022 3:30 pm I am lookIng for a way to reduce the size oF the RMB menu inside the vault.
The menu structure for commands added by an add-in is controlled in the source code of the add-in itself. In the IEdmAddin5::GetAddinInfo method, commands are added via AddCmd, like this:
poCmdMgr.AddCmd(CMD_ADJUST, "Test Addin\\Submneu\\Adjust Properties", (int)(EdmMenuFlags.EdmMenu_OnlyInContextMenu | EdmMenuFlags.EdmMenu_OnlyFiles), "Adjust Custom Properties", "Adjust Custom Properties", -1, 0);
poCmdMgr.AddCmd(CMD_GET_REV_DATA, "Test Addin\\Submneu\\Get Revision Data", (int)(EdmMenuFlags.EdmMenu_OnlyInContextMenu | EdmMenuFlags.EdmMenu_OnlyFiles), "Get Revision Data", "Get Revision Data", -1, 0);
The menu structure is created by separating the menu names with a backslash character '\' which in the source code has to be escaped and is written '\\'. The above code gives a result like this:
If you have access to the add-in source code, change it there. If not, you can try disassembling the add-in(s), tweaking the strings and then re-assembling it. I just did that to add the third item shown here:
so it is possible, as long as the DLL file isn't obfuscated or encrypted or signed.
x 601
x 282
@JSculley thank you very much!
Did you disassemble the dll with resource editor or do you have some other tool you could kindly suggest me?
x 601
x 282
@bnemec
the problem is one "huge" add in the maker didn't care to organize in sub menus... I have requested an improvement in that regard.
my Understanding is the setting of the menu is a per user base, but you can overwrite ALL users from the setup window at the users root iirc.
Answers: 54
x 7
x 815
mp3-250 wrote: Thu Dec 22, 2022 3:55 am @JSculley thank you very much!
If you have Visual Studio, you can use ILDASM.EXE and ILASM.EXE to do the disassembly and reassembly. From a Visual Studio command prompt:
launch the ildasm tool and open the DLL file (make a backup copy in case you make a mistake or it doesn't work for some reason):
From the file menu, select Dump', use the default settings and save the file:
Depending on how the original DLL was built, you may end up with a single .il file, or a .il file and one or more .res files.
You can open the files with a text editor. You then search for the text of your menus, and you will find code like this for each menu item:
Change the first string to have the menu structure you want, using double backslashes to separate them:
Once you have changed them all, you use ILASM.EXE from the developer command prompt to reassemble the code.
E:\SOLIDWORKS Files>ilasm /DLL CustomPropertyCleaner.il
Microsoft (R) .NET Framework IL Assembler.  Version 4.8.3761.0
Copyright (c) Microsoft Corporation.  All rights reserved.
Assembling 'CustomPropertyCleaner.il'  to DLL --> 'CustomPropertyCleaner.dll'
Source file is UTF-8
Class 89
Method Implementations (total): 2
Resolving local member refs: 0 -> 0 defs, 0 refs, 0 unresolved
Writing PE file
Operation completed successfully
If there were one or more .res files, you have to include them as well, so the command would be:
E:\SOLIDWORKS Files>ilasm /DLL /RES=res1.res /RES=res2.res /CustomPropertyCleaner.il
Once this is done, you should have a new DLL file. The tricky part is getting the new DLL into the system and it depends on how your add-in was originally installed. If the vendor just gave you a DLL file and instructions, you should be able to remove the existing add-in DLL and reload the modified DLL using the vendor's instructions.
If it works, you should see your new menu structure, like this:
Also, this will only work for .NET DLL files. If the add-in was written in plain C++, none of this will work. All my tests were done using a C# DLL.
x 601
x 282
@JSculley thank you for the explaination, but the add-in I got is signed and encrypted apparently.
