using openDoc6 browse for missing file.
colt
x 14
x 22
Unread post by colt »
How can I trigger the browse for file popup if using openDoc6?
x 2380
x 1989
Re: using openDoc6 browse for missing file.
Typically the coder launches the file browser dialog, and feeds the values returned to the openDoc function.
This explains how it was done in VB6. I can't say if that is still up to date for the modern Solidworks VB API
http://www.vb-helper.com/howto_select_file.html
colt
x 14
x 22
Whoops, I had this question open in another tab. Must have submitted by accident without giving all info.
Was trying to get this dialog when a referenced part is missing from the drawing
using this code
Dim swApp As Object
    Dim err As Long
    Dim warn As Long
    dim fileP as string
    fileP = "mypath"
    Set res = swApp.OpenDoc6(fileP , swDocumentTypes_e.swDocDRAWING, swOpenDocOptions_e.swOpenDocOptions_Silent, "", err, warn)
    Debug.Print res.GetTitle
    Debug.Print err
    Debug.Print warn
The dialog opens when opening from explorer or from solidworks file menu, but not api. My solution was to open the drawing manually and select Checked "don't show again" before selecting "Browse for file". Now openDoc6 will automatically present the open file window when something is missing.
Stefan Sterk
Answers: 5
x 72
x 88
Unread post by Stefan Sterk »
Hi @colt,
Replace swOpenDocOptions_e.swOpenDocOptions_Silent with Empty or -1.
swOpenDocOptions_e.swOpenDocOptions_Silent suppresses the warning dialogs like missing file.
Set res = swApp.OpenDoc6(fileP , swDocumentTypes_e.swDocDRAWING, Empty, "", err, warn)
Instead of
colt
x 14
x 22
Hmmm, when I use -1 it opens the document as [Viewing] [Read-only]. When Empty it loads as if I had the silent option. I made sure to allow all dismissed messages in options. I am on 2018, so maybe it works in newer versions.
