unable to see all circle relations
Mike Gera
x 94
x 37
Unread post by Mike Gera »
If I have a .SLTPRT sketch that has a fully constrained (x, y, and diameter) circle and I click on the circle itself, I only see the diameter relation under "Existing Relations".
How would I see the x and y relations?
In other words, why aren't the circle's center point relations displaying?
If I click on the center point, sometimes I see the relation I need to, and sometimes I don't.
I feel like clicking on the circle itself should show all relations.
What am I missing?
Thanks for any replies, as always.
by SPerman » Mon Dec 05, 2022 3:14 pm
I have seen the same behavior. The center point and the circumference are treated as two different entities.
I typically use the "Display Relations" button and try and use the filters to narrow it down from there. ( Worst case I just scroll through the available options until I find the one I am looking for.)
SW 2024 SP 5.0
Windows 11
x 2477
x 2098
Re: unable to see all circle relations
Top left circle is constrained vertically to origin (#2)
Top right circle is constrained to nothing
Bottom left circle is constrained coincidently to the origin (#1)
Bottom right circle is constrained horizontally to the origin (#3)
If there isn't a relation, it isn't constrained as far as I know. Do you have examples where that is not the case?
Mike Gera
x 94
x 37
Hey Alex,
If I click on the 1/4" diameter circle in the attached circle_test.SLTPRT file, all I see is the "Diameter7" existing relation.
Even if I use a selection box to select the circle (and, presumably, its center point), all I see is "Diameter7".
-Mike
circle_test.SLDPRT
(29.95 KiB) Downloaded 54 times
SW 2024 SP 5.0
Windows 11
x 2323
x 1950
x 2477
x 2098
Mike Gera wrote: Mon Dec 05, 2022 3:07 pm Hey Alex,
-Mike
Can't open, I'm on 2019 sorry. I've seen what you speak of too, just never have been able to reproduce it whenever it is brought up
Mike Gera
x 94
x 37
It sounds like this behavior is maybe not a "bug" per se but rather weak coding.
SW 2024 SP 5.0
Windows 11
