Display of failed features in an assembly when selecting a part
Posted: Mon Jan 09, 2023 2:44 pm
by BrianHoerner
Folks,
We are currently using SW2022 SP5, and have started noticing that if you select a part that has rebuild errors while in an assembly, there is a drop down showing them. Doesn't matter if you pick in the feature manager or select the part within the assembly, see snapshot below.
I have not been able to find a way to turn this function off, though haven't spent a huge amount of time on this, so am wondering if anyone here has an answer on how to disable this function...features :D
Thanks,
Brian
Re: Display of failed features in an assembly when selecting a part
Posted: Mon Jan 09, 2023 3:11 pm
by JSculley
It's worked that way all the way back to 2017 (the earliest version I have), if not further. I don't think it can be turned on/off. Best way to get rid of it is to fix the model. :D
Posted: Mon Jan 09, 2023 3:40 pm
JSculley wrote: Mon Jan 09, 2023 3:11 pm It's worked that way all the way back to 2017 (the earliest version I have), if not further. I don't think it can be turned on/off. Best way to get rid of it is to fix the model. :D
There is the Pro/E way of forcing you to fix the errors before doing anything else. :twisted:
Posted: Mon Jan 09, 2023 3:59 pm
by BrianHoerner
Thanks, normally only work on good modeled parts :D, so never saw it
