Folks,
We are currently using SW2022 SP5, and have started noticing that if you select a part that has rebuild errors while in an assembly, there is a drop down showing them. Doesn't matter if you pick in the feature manager or select the part within the assembly, see snapshot below.
I have not been able to find a way to turn this function off, though haven't spent a huge amount of time on this, so am wondering if anyone here has an answer on how to disable this function...features
Thanks,
Brian
Display of failed features in an assembly when selecting a part
- x 5
Re: Display of failed features in an assembly when selecting a part
It's worked that way all the way back to 2017 (the earliest version I have), if not further. I don't think it can be turned on/off. Best way to get rid of it is to fix the model.
- x 1138
- x 1942
There is the Pro/E way of forcing you to fix the errors before doing anything else.
- x 5
Thanks, normally only work on good modeled parts , so never saw it
