"Format" layer
The original drawing template contains the "Format" layer.
In none of the possible settings for dimensioning, labeling,.... I have not found a function that uses this layer.
What is this layer needed for?
Format Layer
Format Layer
[quote=Hansjoerg post_id=2439 time=1617359472 user_id=349]
"Format" layer
In none of the possible settings for dimensioning, labeling,.... [b]I have not found a function that uses this layer.[/b]
[/quote]
That doesn't mean it can't be used, you can set your doc options to use this layer as detail entities are created.
If you don't like FORMAT's settings, you can change them (in your template). You can also rename it (again, in your template).
Other than the "FORMAT" layer, there's "None" which isn't controllable (that I know of) since it's not exposed in the Layers dialog.
Kevin
Go to full post"Format" layer
[/quote]
Kevin
- x 1644
- x 2052
Re: Format Layer
I never figured that out either. I finally deleted it from my templates.
Re: Format Layer
I'm guessing the sheet format?
Re: Format Layer
"Format" layer
[/quote]
Kevin
"Format" layer
[/quote]
Kevin
