If I save a part or assembly as a .STEP file and then try to open that .STEP file, the part or assemble is invisible.
The feature tree, however, is fully intact.
Is this a bug perhaps?
Thanks for any help.
Imported .STEP files are invisible
SW 2024 SP 5.0
Windows 11
Windows 11
- x 1636
- x 1467
Re: Imported .STEP files are invisible
Check export setting.
Screen shot?
Share some files?
Difficult to work in the dark.
Screen shot?
Share some files?
Speak for yourself.
- x 1636
- x 1467
I can always shot in the dark.
Buuurrrrrr Buuuurrrrrrr Buuurrrrrrr
Turns out I had "Output as" set to Wireframe and "Export face/edge properties" was unchecked.
That being said, shouldn't a wireframe appear as...something?
Thanks.
Thanks.
SW 2024 SP 5.0
Windows 11
Windows 11
- x 1636
- x 1467
You might have turned off surface and sketch on import.
- matrx20000
- x 1
Hey Mike,
Another workaround if your imported STEP file is invisible:
1. Go to the root node of your feature tree
2. Right-click "break links"
And the imported part/assembly should be visible.
(disclaimer: I don't know if this is the correct way to do it... but it works for me...)
