Heat source?
MJuric
x 873
Heat source?
Unread post by MJuric »
Not real familiar with doing thermal studies so looking for some help.
I have a situation where I have a part that is seeing minimal contact with another hot part, coming out of a HT furnace. That part I got. What I'm not getting is how do I account for the radiation and other heat. When I go to add a radiation loads it asks me for "Exposed faces". Maybe I'm thinking backwards but what I want is to assign values to the object that is hot and have that be a heat source.
The "Exposed surfaces" will have different radiation depending where on the surface they are in comparison to the heat source.
Thank You
Answers: 54
x 7
x 813
Re: Heat source?
Are you using Surface to Ambient radiation instead of Surface to Surface radiation?
