All,
I'm tweaking my clean up utility to be able to unfiy the scene settings in my parts/assemblies.
Doing some spelunking I've come across the DelecteScene function: https://help.solidworks.com/2017/Englis ... Scene.html
To be kind, documentation is kinda sparse.
Has anyone gotten this to work? More importantly has anyone gotten this to work under VBA?
DeleteScene Method (IModelDocExtension)
Re: DeleteScene Method (IModelDocExtension)
It pretty much works as advertised. Here's a before:
And here's the after:
Here's some code:Code: Select all
Dim mDoc As ModelDoc2
Dim mExt As ModelDocExtension
Set mDoc = swApp.ActiveDoc
Set mExt = mDoc.Extension
mExt.DeleteScene
It works for me when I run my code, but I had to test a few things to make sure I knew what was going on.
You can delete a scene, however there needs to be a scene applied to the part so SW re-applies the default theme. This is why it doesn't appear that the scene is deleted from the feature tree.
Works perfectly.JSculley wrote: ↑Wed Feb 15, 2023 7:45 am It pretty much works as advertised. Here's a before:
Here's some code:
And here's the after:Code: Select all
Dim swApp As SldWorks.SldWorks Dim mDoc As ModelDoc2 Dim mExt As ModelDocExtension Sub main() Set swApp = Application.SldWorks Set mDoc = swApp.ActiveDoc Set mExt = mDoc.Extension mExt.DeleteScene End Sub
Thank you
