WIP for every part?
x 1231
WIP for every part?
This is a conversation we just had today. Should all parts/items perpetually have one WIP revision on top of all released revisions? I thought it's a less-than-great idea, even though General Motors does it. But there is an upside; it allows you to make clerical changes without forcing a revision or an unrelease to fix a misspelling.
How do the rest of you do this?
by AlexB » Thu Feb 16, 2023 4:45 pm
That seems like a workaround to how PDM is intended to work... and we use PDM. It's there to lock down files so people cannot change them. If clerical corrections or other modifications that don't impact the "geometry" of the part are needed then that can be done on the issued versions of files with a relatively strict review.
x 278
x 462
Re: WIP for every part?
Answers: 32
x 1253
x 2045
We have a "Correction" workflow that increments the revision by 0. So we end up with two or more of the same revision letter sometimes. This workflow is only for small model issues that need to be repaired (mates, sketch relations) or to add configurations needed for an assembly. If we had to bump a revision, it would require an ECO and our factory would be mighty upset since they would have to update the revision letter in several of their systems.
x 2575
x 1423
jcapriotti wrote: Thu Feb 16, 2023 5:02 pm We have a "Correction" workflow that increments the revision by 0. So we end up with two or more of the same revision letter sometimes. This workflow is only for small model issues that need to be repaired (mates, sketch relations) or to add configurations needed for an assembly. If we had to bump a revision, it would require an ECO and our factory would be mighty upset since they would have to update the revision letter in several of their systems.
Yep, we added one to. Abusers will still abuse. But at least there's a trail now.
x 893
We call it a 'Non-Revision Change'. I drill it into users that it is primarily to make corrections to parts that haven't 'escaped' Engineering (i.e. they haven't hit the shop floor) or for changes that are strictly clerical (misspellings in a note, adding a missing dimension, etc). They are also absolutely necessary if you require your part and drawing to have the same revision. If I change a part to do something like hide a sketch or a plane, it has no impact on anything in the real world. Without a non-revision change, the drawing would have to be revised, and the revision description would be completely meaningless in the context of the drawing.
x 2489
x 1899
JSculley wrote: Thu Feb 16, 2023 6:52 pm We call it a 'Non-Revision Change'. I drill it into users that it is primarily to make corrections to parts that haven't 'escaped' Engineering (i.e. they haven't hit the shop floor) or for changes that are strictly clerical (misspellings in a note, adding a missing dimension, etc). They are also absolutely necessary if you require your part and drawing to have the same revision. If I change a part to do something like hide a sketch or a plane, it has no impact on anything in the real world. Without a non-revision change, the drawing would have to be revised, and the revision description would be completely meaningless in the context of the drawing.
Could you add a X.X stage to track these changes? So for these changes you'd see 0.1, 0.2, etc. That way these fixes are documented in the system and can be recorded. Though from your description it may be more trouble than it is worth.
x 893
mattpeneguy wrote: Fri Feb 17, 2023 8:09 am Could you add a X.X stage to track these changes? So for these changes you'd see 0.1, 0.2, etc. That way these fixes are documented in the system and can be recorded. Though from your description it may be more trouble than it is worth.
Yes we could, but typically no one cares that much about these minor changes. We can always look at the file history. I train users to always include a comment in the transition dialog when completing the change so that there is a record of what happened, even if it doesn't show up on the drawing document.
x 1231
That's the issue we face. If we make a clerical mistake or forget to fix a mate, it sucks to have to make a new revision. At the same time unrelease can be a scary thing in the hands of some users. Right now I'm considering making a privileged EO workflow that unreleases the target part, goes to the assigned worker's tasklist for completion, and then when approved the part is released again. That way we still have a paper trail and we can build in some safety checks as well.
I thought perpetual WIPs sounds like a sleazy hack, but I wanted to get some input from more experienced folks. Thanks!
Answers: 32
x 1253
x 2045
@mike miller We don't unrelease anything with our correction workflow. The file moves from the "Release" state to "Correction" which only a small group can access. For the rest of the company they can only pull the "Release state version. Once the correction is done and submitted it goes to a review state then back to Release.
Brian-M
x 52
x 17
Unread post by Brian-M »
Correction workflow is a good idea, and that is the way to go for the whole organization and making minor edits.
But I wanted to mention that there are two alternatives for behinds the scenes admin magic in Solidworks PDM. Caution recommended.
First the admin gets permission to check-out from the Approved end state (I only turn this on temporarily).
1) Make a very safe change (like adding reference geometry to a sldprt), and check-in. The check-in action removes the Revision stamp. Next use Modify >> Set Revision to restore the revision (use Ctrl+N to keep same revision as rev variable on data card).
Set Rev, Ctrl+N
Set Rev, Ctrl+N
2) The same but on check-in use the checkbox Overwrite Latest Version. This keeps the same revision, but replaces the file, so no safety net at all. Fewer steps but more risky.
Overwrite
Overwrite
Probably a bad idea to encourage this backdoor, but occasionally helpful, and I find it interesting. Also might end up taking too much admin time if this was the only solution.
x 742
x 361
As admin I rollback or latest overwrite to make the correction myself.
Never trust the end user...
x 742
x 361
We do it all the time with latest overwrite.
If the correction iscatched quickly a rollback is also ok, but you must be careful of some PDM bug.
Brian-M wrote: Fri Jan 03, 2025 5:57 pm Correction workflow is a good idea, and that is the way to go for the whole organization and making minor edits.
