Need HELP for Macro to add new custom property with ConfigName!
Library for macros
VictorPleg
Unread post by VictorPleg »
Hello!
I am new to the world of macros, as well as to the programming language.
I need a macro to add a new custom property (which will always be called the same) and put in its 'Value/Text Expression' the evaluated value that binds to the configuration name property ($PRP:"SW-Configuration Name").
This is the value I need to write to the custom property:
And this is how the result would look after executing the desired macro:
I don't know how I can integrate this into the code...
It's possible?
I found a macro to be able to add a new custom property. But this only allows you to add the property name and value manually.
This is the macro:
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim boolstatus As Boolean
Dim Code As String
 Sub setcode()
Code = "SIF0030010503M5"
setcode
Set swModel = swApp.ActiveDoc
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
swCustPropMgr.Add3 "DENOM. SIF", swCustomInfoText, Code, swCustomPropertyReplaceValue
The purpose of the macro is:
- Add (in the active document) a new property called 'DENOM. SIF', whose value or text expression is the result of the formula $PRP:"SW-Configuration Name" (In the macro that I show I have added the value manually --> Code = "SIF0030010503M5")
- Save the Part.
- Close the document.
I would greatly appreciate a little help.
Thanks in advance.
x 2312
x 1948
Re: Need HELP for Macro to add new custom property with ConfigName!
x 278
x 462
I'm not sure why you need it to work this way, but is this what you're looking for?
- Add property to link to configuration name
- Read property to get property name that it's evaluated to
- Rewrite property value to hard-coded configuration name
Option Explicit
    Const NAME_OF_CFG As String = ""
    Const NAME_OF_PROPERTY_TO_ADD As String = "NEWPROP"
    Const VALUE_OF_PROPERTY_TO_ADD As String = "$PRP:""SW-Configuration Name"""
    Dim swModel As ModelDoc2
    Dim swExt As ModelDocExtension
    Dim swCustPropMgr As CustomPropertyManager
    Dim swResolvedValue As String
    Dim swValue As String
    Set swExt = swModel.Extension
    Set swCustPropMgr = swExt.CustomPropertyManager(NAME_OF_CFG)
    swCustPropMgr.Add3 NAME_OF_PROPERTY_TO_ADD, swCustomInfoType_e.swCustomInfoText, VALUE_OF_PROPERTY_TO_ADD, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
    swCustPropMgr.Get3 NAME_OF_PROPERTY_TO_ADD, False, swValue, swResolvedValue
    swCustPropMgr.Add3 NAME_OF_PROPERTY_TO_ADD, swCustomInfoType_e.swCustomInfoText, swResolvedValue, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue
VictorPleg
Thank you very much Alex B!
It's very similar to what I need!
The only thing different is the property name has to always be 'DENOM. SIF' instead of 'NEWPROP'.
I have tried to replace it in the code, but then it creates 2 properties, one called 'NEWPROP' and the other called 'DENOM. SIF'
Do you know how I could modify the code so that this doesn't happen?
Excuse my ignorance, but the reality is that I don't know how to read this programming language very well...
This is how it looks if I do what I mentioned instead:
thanks a lot!
It's almost ready!
VictorPleg
Actually, I notice that every time I modify that parameter again ('NEWPROP') and assign it another value, like for example 'Victor'
And if I then manually delete the properties written by the macro and run it again, then it creates 3 new properties. 'NEWPROP', 'DENOM. SIF' AND 'VICTOR'.
As you can see in the screenshot:
That's why what I need is to always write the named property 'DENOM. SIF' and if it already exists, rewrite it.
And that in such a case, the name of the property can be configured in the same macro (which in this case must always be 'DENOM. SIF')
I don't know if I'm explaining myself well...
Thanks again.
x 278
x 462
This should work now. I shouldn't have used "Const" for the settings it seems.
Option Explicit
    Dim NAME_OF_CFG As String
    Dim NAME_OF_PROPERTY_TO_ADD As String
    Dim VALUE_OF_PROPERTY_TO_ADD As String
    NAME_OF_CFG = ""
    NAME_OF_PROPERTY_TO_ADD = "NEWPROP3"
    VALUE_OF_PROPERTY_TO_ADD = "$PRP:""SW-Configuration Name"""
