How to link to another part
Uncle_Hairball
x 37
x 95
I'm working on an assembly and trying to link the height of a linear pattern to the height of the part being patterned. Somehow, I need to add the part name to the variable I'm using, but cannot figure out the syntax. It's got to be something like "D1@Boss-Extrude1.Part_Name", but SW isn't happy with that.
x 1761
x 2132
Re: How to link to another part
In a case like that I don't bother with syntax. I create a sketch in the Assembly with a vertical construction line, with both ends fully defined by relations (in your case the end points would be coincident with the top and bottom of the Part). Insert a driven dimension for the line length and close the sketch.
Set up a global variable linked to this dimension, then reference that global variable in the linear pattern. I didn't give a lot of detail on that last part, but feel free to ask if you have questions.
x 2232
x 1878
There is also the "up to reference" option in the linear pattern, but it can be finicky. Glenn's approach is a good one.
XHawkeye
x 58
x 44
Unread post by XHawkeye »
"D1@Boss-Extrude1@Part_Name<#>.Part"
x 1643
x 1471
Use SSP or Master Skeleton.
Linking parts in assembly is fast and easy but difficult to manage.
Do that on a few parts is ok.
When you got more parts, it'll be impossible to avoid cyclic links.
It means changing one part cause other parts to change and change that part again in a never ending loop.
x 1761
x 2132
Frederick_Law wrote: Thu Feb 23, 2023 2:54 pm Use SSP or Master Skeleton.
I will agree that you can run into problems with external references, but that shouldn't be an issue using one Parts dimensions to drive a linear pattern in an Assembly (which is what the OP asked for).
x 1643
x 1471
True, if it's only part to assembly feature.
Uncle_Hairball
x 37
x 95
Thank you all for your advice. XHawkeye's advice is exactly what I was looking for.
sergio.monti
x 48
x 21
Unread post by sergio.monti »
There also a quick way to do it. Create the pattern first, then double click on the pattern items in the tree -> double click on the dimension of the pattern and edit typing "=" and click on the dimension to link on the part. See gif attacched.
