Is there a way to show a sheet metal part's K factor on the .SLDDRW?
Mike Gera
x 79
x 33
Unread post by Mike Gera »
If I have an .SLDDRW of a sheet metal part, is there a way to link text on that .SLDDRW to the part's K-factor?
Thanks.
SW 2022 SP 5.0
Windows 11
x 384
x 417
Re: Is there a way to show a sheet metal part's K factor on the .SLDDRW?
You can link a note to Bend Allowance cut list property.
Mike Gera
x 79
x 33
gupta9665 wrote: Sat Mar 18, 2023 12:17 pm You can link a note to Bend Allowance cut list property.
Thanks, Deepak.
Now to ask an ignorant question, but how do I do that?
SW 2022 SP 5.0
Windows 11
x 384
x 417
Add a note in the drawing attached to the view and link to the custom property "Bend Allowance" as shown in attached video.
Link Note to Bend Allowance.mp4
(4.24 MiB) Downloaded 106 times
TTevolve
x 78
x 145
Unread post by TTevolve »
Make sure to update, or pick update automatically on the cut list of the part or the cultist options won't appear when you go to add them to the note.
Mike Gera
x 79
x 33
gupta9665 wrote: Sun Mar 19, 2023 1:16 am Add a note in the drawing attached to the view and link to the custom property "Bend Allowance" as shown in attached video.
Thanks for the video, it was extremely helpful.
One thing that I should have mentioned in my original post, though: I want the K-Factor to appear in my title block (i.e. it will be just text, not a leader that is ultimately associated with an .SLDPRT).
SW 2022 SP 5.0
Windows 11
x 384
x 417
Use the same method and select "drawing view specified in Sheet properties" option.
Mike Gera
x 79
x 33
Deepak,
Thanks for your help. Below is what I see:
2023-03-20 13_18_42-SOLIDWORKS Premium 2022 SP5.0 - [8126-06 - Sheet1 _].png
SW 2022 SP 5.0
Windows 11
Dennis Bacon
x 18
x 30
Unread post by Dennis Bacon »
I suppose that you could add that in your "Custom Properties".. Something like this. I added the words "k-factor=" in and got the syntax from "Cut List Properties" cut and paste.
The value is the k-factor value from the "Sheet-Metal" dialog ,which of course your can set that to what is appropriate.
In the drawing you can link a note or text in the bom or title block to that.
x 2191
x 1892
Dennis Bacon wrote: Tue Mar 21, 2023 6:28 pm I suppose that you could add that in your "Custom Properties".. Something like this. I added the words "k-factor=" in and got the syntax from "Cut List Properties" cut and paste. image.png The value is the k-factor value from the "Sheet-Metal" dialog ,which of course your can set that to what is appropriate.image.png In the drawing you can link a note or text in the bom or title block to that.image.pngimage.pngimage.png
This is what I would go with, careful though, annotations can sometimes be tricky to get to update. Generally not in parts though.
Mike Gera
x 79
x 33
Lots of good, helpful ideas here, but it sounds like there is no direct way to line a note to part's bend allowance data.
SW 2022 SP 5.0
Windows 11
x 384
x 417
Mike Gera wrote: Tue Mar 21, 2023 4:43 pm Deepak,
Sorry forgot that cut list won't appear in the list unless you attach to the model. SO like @Dennis Bacon said, you will have to use the custom property route.
