need macro help
mraycii
x 3
need macro help
Unread post by mraycii »
I'm a total noob at writing code.
I'm trying to write a macro which will do the following:
1.) ensure the check is "on" next to "Show Configuration Names" under Tree Display in the Configuration tab
2.) ensure the check is "on" next to "Show Configuration Descriptions" under Tree Display in the Configuration tab
3.) ensure the check is "on" next to "Numeric" under Tree Order in the Configuration tab
This area is accessed by navigating to the configurations tab in a .sldprt file, then right clicking on the header at the top of the list of configurations.
Here is the code I've written so far (it will turn on the configuration name and configuration description). I just can't get the "Numeric" turned on under Tree Order.
Any help you could provide would be greatly appreciated.
by zwei » Thu Mar 30, 2023 12:51 am
Option Explicit
Dim Model As ModelDoc2
Dim ConfigMgr As ConfigurationManager
Dim v As Variant
Dim i As Long
Set Model = swApp.ActiveDoc
Set ConfigMgr = Model.ConfigurationManager
ConfigMgr.ShowConfigurationDescriptions = True
ConfigMgr.ShowConfigurationNames = True
ConfigMgr.SortConfigurationTree swSortType_Numeric
Answers: 13
x 2023
x 1691
Re: need macro help
Does this do what you want? I am on 2022, so I don't have the same options you show.
https://help.solidworks.com/2021/englis ... ple_VB.htm
x 599
Re: need macro help
Option Explicit
Dim v As Variant
Dim i As Long
mraycii
x 3
Re: need macro help
Zhen-Wei Tee wrote: Thu Mar 30, 2023 12:51 am
Outstanding! It worked wonderfully. Thanks very much for your help.
