Another day another broken PDM tool
Discuss SolidWorks PDM
x 742
x 361
A dept. requested a SW to ACIS(.sat) convertion and asked me if it would be possible to convert data In batch from the vault.
So I setup a convert task, but I noticed that the ACIS options allow the file convertion up to acis v18 while from SW saveas dialog it allows up to v27... =)
so I tested the PDM convert set to v18, opened the .sat file in notepad and the header sais... v27!
wait... it was set to v18 so what about I set it to v10? again the output from the pdm task was v27! =)
what about v8, v16... always v27! =)
I sent the feedback to my var, mainly for the LULZ at this point.
o[
PS
I tried also to insert the version value in the script bypassing the variable from the task convertion option drop down menu... v27!
by mp3-250 » Fri Apr 07, 2023 1:39 am
Solution
[SPR#1196395]
Convert for ACIS does not work, due to incorrect swOutputVersion variable in the script
wrong
swApp.SetUserPreferenceIntegerValue swOutputVersion, [AcisVersion]
correct
swApp.SetUserPreferenceIntegerValue swAcisOutputVersion, [AcisVersion]
Also there are 2 check boxes missing in the task settings (which incidentally I needed to disable!)
I forced them off in the script with:
swApp.SetUserPreferenceToggle swSATExportSplitPeriodic,false
swApp.SetUserPreferenceToggle swSATExportFaceEdgeProps,false
x 742
x 361
Re: Another day another broken PDM tool (ACIS conver task)
Solution
[SPR#1196395]
wrong
correct
