Just now I added a BOM to my assembly model, something I don't do so often. I found that selecting the line number in the BOM (so the whole line goes gray) would select the components (turns the items blue in the graphics window). I saved and reopened, and now it won't do that. Is there a way to bring it back?
Selecting from Assy Model BOM
- x 2204
- x 1903
Re: Selecting from Assy Model BOM
Hrm, I don't think it's a setting. Could your assembly have errors in it and that would then perhaps explain why it is not highlighting these...?Dwight wrote: ↑Fri Apr 28, 2023 11:40 am Just now I added a BOM to my assembly model, something I don't do so often. I found that selecting the line number in the BOM (so the whole line goes gray) would select the components (turns the items blue in the graphics window). I saved and reopened, and now it won't do that. Is there a way to bring it back?
Have you checked if in a drawing it still works? (Have a 3D View and create a BOM in the drawing from it and then select the item line as you did in the model)
No errors shown. I have a drawing with a BOM, and selections there are highlighted. I created the assembly BOM after the drawing BOM. Maybe because I turned on "follow Assembly Order" option? I don't know. I keep banging on it. SW2022 sp 5AlexLachance wrote: ↑Fri Apr 28, 2023 12:50 pm Hrm, I don't think it's a setting. Could your assembly have errors in it and that would then perhaps explain why it is not highlighting these...?
Is it just that one assembly? Did you change any other setting?
- x 2204
- x 1903
Just a thought, does your assembly have multiple configurations? If so, could the BOM be linked to another config?
