In Context References
I have an assembly that had in context references for wire packaging. I did a "Save As" on this assembly for an FE study. None of the original parts or sub assemblies exist any longer in this assembly, but I cannot get the in context references to go away. Is this a bug? (2022 SP5) or is there a way to get rid of them?
Right clicking doesn't show any options that seem helpful.
I think that this is the post that I was thinking of:
https://r1132100503382-eu1-3dswym.3dexp ... N47mgL5Qng
Go to full posthttps://r1132100503382-eu1-3dswym.3dexp ... N47mgL5Qng
- x 1661
- x 2060
Re: In Context References
I see the option isn't in the right click menu, but have you tried selecting one and hitting the Delete key on your keyboard?
Yes. Nothing happens.Glenn Schroeder wrote: ↑Tue May 02, 2023 11:36 am I see the option isn't in the right click menu, but have you tried selecting one and hitting the Delete key on your keyboard?
What about "Purge Unused Features?"
- x 760
- x 911
I remember seeing a question very similar to this on the old forum. I don't remember if it was answered or not, but I DO remember that a bunch of heavy-hitters chimed in. Let me see if I can figure out the search function on the SWYM and find it.
That doesn't do anything either.
- x 1141
- x 1947
- x 760
- x 911
- x 2204
- x 1903
Dayum, Mr. Pogue, that's a name I haven't seen in a while.DanPihlaja wrote: ↑Tue May 02, 2023 3:40 pm I think that this is the post that I was thinking of:
Edit: Are the parts supressed in the assembly? That would explain the feature appearing but being suppressed
I'm not sure this solves the problem, but it at least makes it where I don't have to look at them in the history tree.DanPihlaja wrote: ↑Tue May 02, 2023 3:40 pm I think that this is the post that I was thinking of:
No. All of the sub assemblies were dissolved, and any parts that were remaining were saved with new part numbers for FE.
- x 1141
- x 1947
Well, I was able to reproduce it by creating an in-context part in an assembly, saved to disk. Then I add a sub-assy and drag the in-context part to the sub-assy and save. Then I close everything and open the sub-assy and delete the part and save. Then reopen top level assembly......got the orphaned update holders. Don't see a way to clean them up.....maybe there is an API method.
The link Dan posted above goes back to 2017. This isn't new.
- x 1141
- x 1947
I bet it goes back to the beginning....or at least when they added the ability to reorganize the tree structure easily. The early days you couldn't reorder parts into sub-assy's in the tree.
- x 760
- x 911
If I remember correctly, they added the updated holders at one point, but not a way to hide them. They got so many complaints that later, they added a way to hide them. Pretty sure that was as far as they took it.jcapriotti wrote: ↑Tue May 02, 2023 4:52 pm I bet it goes back to the beginning....or at least when they added the ability to reorganize the tree structure easily. The early days you couldn't reorder parts into sub-assy's in the tree.
- x 1141
- x 1947
2001 added the ability to hide them. I think "in-context" was added around 97 - 98. We've always hid them in our templates since the option was available, just never saw the point in them showing. Plus we don't use in-context relations except in some conceptual work. The entire concept needs to be revamped in SolidWorks..DanPihlaja wrote: ↑Wed May 03, 2023 11:34 am If I remember correctly, they added the updated holders at one point, but not a way to hide them. They got so many complaints that later, they added a way to hide them. Pretty sure that was as far as they took it.
