Problem with External Referenced documents
Tera
x 513
x 92
Unread post by Tera »
At times when I open an assembly Solidworks shows the following dialog.
No matter which option I choose, the result is the same. All components of the assembly are virtual.
When I open the references, I can't even find a reference to an external file.
Why Solidworks asks for confimations to open/not open referenced files?
thank you.
Edit:
I just noticed I've used some custom holes from library but I always tick off the "Link to library" checkbox.
Can it be the case? If yes, why references screen doesn't show any reference to the library file?
ellundo
x 18
Re: Problem with External Referenced documents
Unread post by ellundo »
Just a guess but the "In Context" relations you show might be the cause of your problem.
x 2542
x 2139
Tera wrote: Wed May 10, 2023 8:20 pm At times when I open an assembly Solidworks shows the following dialog.
thank you.
Edit:
I believe that even if a component is virtual inside an assembly, if it has a reference to something else, it is an "external reference", in the sense that the reference is not contained within the part's file. Even if the part is virtual, there is still a file structure within your assembly and the part's reference does not come from the part but from something else in the assembly.
