Rotate dimension text.
What I have is the image on the left. What I want is the image on the right. Is there any way to force SW to do this? I can't find a way to get a diameter dimension to rotate 90 degrees.
Re: Rotate dimension text.
I don't think it's possible. There are several SPRs requesting it.
Thanks.
- x 1158
- x 1958
- x 1727
- x 2111
I can too, and it's not that difficult if it's just a one time thing. I wouldn't want to have to do it all the time.jcapriotti wrote: ↑Thu May 11, 2023 5:11 pm I can give you a crappy workaround, not sure it's worth it though.
I assume I can make a note and link it to the dimension value. Whatever the suggestion, I'm probably not going to want to do it 15 times.
- x 1158
- x 1958
Pretty much it, note and link to dimension value. I think the reason you can't rotate it is it's per Ansi standard.
- x 1727
- x 2111
That was what I had in mind, but after seeing your screenshot I thought of something else that might work in this situation. Have you considered hiding the dimension lines? You could set one dimension up that way and save it as a Style, which could then be easily applied to the other ones.
- x 791
- x 952
What about using ordinate dimensions?
