Drawing Labels
Drawing Labels
Is there a way to set the automatic Section & Detail labeling so that if I have a multi-sheet drawing, it will have labels start at "A" for each sheet in the drawing file?
- x 1729
- x 2111
Re: Drawing Labels
I'm pretty sure the answer is no. Why would you want to?
Re: Drawing Labels
Drawing starts out single sheet, becomes multiple sheets, then later gets split into separate drawings. For instance Part detail sheets get worked on a separate sheet than the installation context drawings. Then file gets too big and slow, so it has to get split into separate files.
- x 2489
- x 1899
Re: Drawing Labels
You can try the following macro when you separate the sheets out. It'll rename the views starting with A.
Const A_CHAR As Integer = 65
Const Z_CHAR As Integer = 90
Dim swDraw As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim curChar As Integer
Dim curChar2 As Integer
Dim curChar3 As Integer
Set swDraw = swApp.ActiveDoc
If swDraw Is Nothing Then
MsgBox "Please open drawing document"
End
Dim vSheetNames() As String
vSheetNames = swDraw.GetSheetNames
Dim sheetInd As Integer
curChar = A_CHAR
curChar2 = A_CHAR
curChar3 = A_CHAR
For sheetInd = 0 To UBound(vSheetNames)
swDraw.ActivateSheet vSheetNames(sheetInd)
Set swSheet = swDraw.Sheet(vSheetNames(sheetInd))
Dim vViews As Variant
vViews = swSheet.GetViews
Dim i As Integer
'Debug.Print UBound(vViews)
'If UBound(vViews) Is Nothing Then
' if sheet has no views skip
'Else
For i = 0 To UBound(vViews)
Dim swView As SldWorks.View
Set swView = vViews(i)
Select Case swView.Type
Case swDrawingViewTypes_e.swDrawingSectionView
Dim swSectionView As SldWorks.DrSection
Set swSectionView = swView.GetSection
Debug.Print swSectionView.GetLabel
swSectionView.SetLabel2 GetNextName
Case swDrawingViewTypes_e.swDrawingDetailView
Dim swDetailedView As SldWorks.DetailCircle
Set swDetailedView = swView.GetDetail
Debug.Print swDetailedView.GetLabel
swDetailedView.SetLabel GetNextName
End Select
Next
'End If
Next
swDraw.ForceRebuild
Function GetNextName() As String
If curChar > Z_CHAR Then
If curChar2 > Z_CHAR Then
MsgBox ("Overflow")
End
Else
If curChar3 > Z_CHAR Then
curChar3 = A_CHAR
curChar2 = curChar2 + 1
' FirstLet = curChar2
' SecondLet = curChar3
GetNextName = Chr(curChar2) & Chr(curChar3)
curChar3 = curChar3 + 1
Else
GetNextName = Chr(curChar)
curChar = curChar + 1
End Function
- x 2489
- x 1899
Re: Drawing Labels
Fair warning though, it was made for a drawing file with multiple sheets. I suppose you could modify it to iterate through each sheet in the drawing and rename starting with A for each sheet. But, because the file already has an "A" view when you get to sheet 2, it will probably give you an error.
Re: Drawing Labels
Great Thanks! I'll definitely try it out!mattpeneguy wrote: ↑Tue May 16, 2023 4:03 pm You can try the following macro when you separate the sheets out. It'll rename the views starting with A.
- x 2489
- x 1899
Re: Drawing Labels
Good luck and let us know how it works. If you modify it to work on a multisheet drawing with each sheet starting at "A", post it back here for others who may get use out of it.
Credit to where credit is due, Deepak Gupta helped me with that macro several years ago on the old forum.
I'm not really a coder, but I can kludge things together with some help from people who know what they're doing.
