I did a bunch of parts detials for and assembly under a single drawing that has multiple sheets (3 to 4 sheets per drawing). I need to export the as DXF/DWG drawings to get sent out for laser cutting, but when I do the save as and select DXF or dwg it only saves the first sheet in the packet of drawings. Is there a way to have it export all of the sheets at the same time?
I went through and did some of them by deleting the sheets I don't want and saving it as a dxf, then re-opening, going to the 2nd sheet, deleting the rest and saving it as a dxf. then doing the 3rd sheet and so on.
Exporting SW multi-sheet Drwaings to DXF/DWG
- x 2489
- x 1899
Re: Exporting SW multi-sheet Drwaings to DXF/DWG
System Options>Export
Then choose DXF/DWG in the File Format dropdown.
Then choose what you want:
