I have 3 components of the same type that have mysteriously become hidden in an assembly. They are the curved strips in the screenshot. I can't make them show. it happened after I mirrored them. Hav since deleted the mirror. The only way I can get them to temporarily show up is to is to select in the path finder and use "Select related Faces". The part opens fine. If I drag in another copy of the part from path finder that is visible. The part also shows up if I select Edit Definition.
Any ideas on the cause of this? Obviously I can just delete and re -insert them.
Part Bodies hiding in an assembly
Doesn't look like your STEP file has any geometry in it. Ran it through the NIST STEP Analyzer to confirm.
Go to full postRe: Part Bodies hiding in an assembly
I partially found the cause of the problem. The curved strip is imported as a sheet metal part. Yet SE can't convert it to sheet metal apparently because there are no straight edges. The mass properties are 0. It should weigh about 12-20 grams. Do SE it sort of treating it as surfaces. In the assembly it initially shows ok but when mirrored it hides. I made it redisplay by show hide component -ticking surfaces. So that solves my direct problem.
As an aside
How would one convert this to sheet metal.
Can you get pattern recognise to pickup the 8 holes
Attached is the file in step 242 format as I am using the community version.
As an aside
- Curved Strip 4`5' rad 89b.stp
- (2.6 KiB) Downloaded 121 times
