Hello all,
I need to change the Sketch plane to a Geometry plane that I defined. But it seems I can't change the plane to the Geometry plane in the "Edit Sketch plane" option.
I will be grateful if you could help me.
Change Sketch plane to a Geometry plane
- x 5
Re: Change Sketch plane to a Geometry plane
The plane you created and that you want to use for the sketch has to before the feature you want to use it for in the tree. Reorder the plane to before the feature then do change sketch plane.
- x 2305
- x 1974
If you're having trouble creating the plane where you desire, you can bring the rollback bar up and then create the plane so that it creates itself at the desired place in the feature tree. Your issue lies in the fact that the plane uses geometry that was created after the sketch.
