Ordinate text in the wrong place
- x 27
- x 90
I know this problem has been around forever. Ordinate dimension text is on the wrong side of the leader. Has anyone found a solution for it?
- x 176
- x 214
Re: Ordinate text in the wrong place
Don't see it in SW2019. Could you share some example files?
- x 749
- x 907
His example is in a sketch in the 3d environment.Frank_Oostendorp wrote: ↑Thu Jun 15, 2023 4:51 am Don't see it in SW2019. Could you share some example files?
Your example is in the drawing environment. Very different animals.
I agree, I see this ALL THE TIME in the sketch environment, and I don't know how to fix it. But since I don't use the sketch dimensions visually for anything other than model data, it hasn't been a big issue for me.
- x 2187
- x 1887
Never dealt with it either so can't be of much help. Maybe it has to do with line directions?
- x 1644
- x 2054
I'm with @DanPihlaja. I rarely use ordinate dimensions in model sketches, though I use them often in drawings. Even if I did get that behavior when using them in a model sketch I wouldn't care.
I see a similar behavior in drawings, but it is always at the other end, never at the dimension end. The only fix I've found for that is to delete it and recreate it. (I didn't even know you could use ordinate dimensions in a sketch.)
- x 176
- x 214
Never to old to learn. What is the sketch in the 3D environment? A sketch to create a feature in a part? Like the one below?DanPihlaja wrote: ↑Thu Jun 15, 2023 9:16 am His example is in a sketch in the 3d environment.
- x 1644
- x 2054
The option shown below doesn't work with ordinate dimensions, which is one big reason why I rarely use them in model sketches.
I use them for speed, one click per dimension, if you have a lot it goes quick. I then go back and give each the dimension it needs. I have seen what the OP got but it's not a problem for sketches.
- x 749
- x 907
Late to the party, but the answer is yes. A sketch at the part/assembly level.Frank_Oostendorp wrote: ↑Thu Jun 15, 2023 10:49 am Never to old to learn. What is the sketch in the 3D environment? A sketch to create a feature in a part? Like the one below?
- x 176
- x 214
Either way, never saw it in my files. Can you share an example? Finally one thing that works as I expected in my version of SolidWorks. Many times my expectations don't meet SolidWorks intentions.DanPihlaja wrote: ↑Fri Sep 01, 2023 9:54 am Late to the party, but the answer is yes. A sketch at the part/assembly level.
