Is there a way to compare configurations on a part, so I can see what Features are suppressed / active for each configuration?
It could be useful for preparing shop drawings so I can create a "master 'part" that many other configurations are derived from.
Configuration Study
Re: Configuration Study
Insert a Design Table and choose the "Auto Create" option. It will automatically add every feature/dimension/etc. that varies across configs. You can delete the design table afterward if you don't want to keep it.
- x 48
- x 21
If you select all the wanted features on the feature tree (hold CTRL) > RMB > Configure feature you get a table where you can see where each feature is suppressed or be able to suppress/unsuppress feature on each configuration. That table work like an excel spreadsheet (copy/paste, fill by dragging the little square spot)
I have to say it has been years since I needed to use Design Tables, but I'm in it now. Useful as heck.
Wow.
I use them on almost every part/assembly.
Would love.love.love if drawings had configurations.
Revision management would then be a piece of cake....
chris
