Using Camera Views in Drawings
Posted: Wed Jun 21, 2023 4:52 pm
by tsmith
Is it possible to use a camera view directly in a drawing?
Current procedure is to setup the camera view and then 'save as' a PNG and then insert a picture.
Or is this a 'feature' in Visualize?
Re: Using Camera Views in Drawings
Posted: Thu Jun 22, 2023 2:39 am
by JuTu
I dont know if camera views are possible, but you can save the viewport orientation as a "named" View that can be used in drawings from the View palette or View properties manager. Then, utilizing Display states you can show or hide components that are needed or not needed.
Also, it is possible to reorient almost any view type if necessary.
Posted: Thu Jun 22, 2023 7:43 am
by JSculley
From the Knowledge Base (
https://support.3ds.com/knowledge-base/ ... 0000116774)
QUESTION: Can a camera view be inserted in a drawing?
ANSWER: No, camera view is only available for models, not drawings.
And SPR 333953 requesting the ability.
https://support.3ds.com/knowledge-base/ ... :SPR333953
Posted: Thu Jun 22, 2023 3:25 pm
by tsmith
