part sketch driven .SLDDRW lines not updating
Posted: Tue Jul 25, 2023 2:43 pm
by Mike Gera
I occasionally use .SLDDRW lines that are driven by a part sketch. Please see attached example.
Note that the notch in the lower-left corner is out of sync with the driving part sketch.
What causes this, and how is it corrected?
Re: part sketch driven .SLDDRW lines not updating
Posted: Tue Jul 25, 2023 3:40 pm
by JSculley
You have two over-constrained sketch relations in your drawing sketch:
They are preventing the sketch from updating correctly
Posted: Tue Jul 25, 2023 3:52 pm
by Mike Gera
JSculley wrote: ↑Tue Jul 25, 2023 3:40 pm
Thanks!
This (type of) problem has been bugging me for literally months.
I wonder why I wasn't seeing an error message.
Posted: Tue Jul 25, 2023 3:56 pm
Mike Gera wrote: ↑Tue Jul 25, 2023 3:52 pm
Thanks!
If you will set relations to show when you're working with an active sketch then ones with problems will be red or yellow instead of green, which will indicate a problem.
Posted: Tue Jul 25, 2023 8:50 pm
by Mike Gera
Glenn Schroeder wrote: ↑Tue Jul 25, 2023 3:56 pm
Hey Glenn, thanks.
Specifically, what setting would that be?
Posted: Tue Jul 25, 2023 9:01 pm
https://help.solidworks.com/2021/englis ... le_Display
How do I toggle the display of sketch relations?
Click View Sketch Relations (View toolbar) or View > Hide/Show > Sketch Relations to toggle the display of sketch relations. If you clear View > Hide/Show > Sketch Relations , but you select a sketch entity in an open sketch, the sketch relation icons appear.
Posted: Wed Jul 26, 2023 7:23 am
by JSculley
SPerman wrote: ↑Tue Jul 25, 2023 9:01 pm
In a drawing, you have to go a step further. The only way to see the relations is to click on a sketch element on the drawing or the sketch feature of the model in the feature tree.
Posted: Wed Jul 26, 2023 7:25 am
by Mike Gera
JSculley wrote: ↑Wed Jul 26, 2023 7:23 am
I noticed that as well. Thanks.
Is there a setting that will throw an error when over-definition occurs in an .SLDDRW?
Posted: Wed Jul 26, 2023 8:41 am
Mike Gera wrote: ↑Wed Jul 26, 2023 7:25 am
You should get one or more notifications near the bottom of your monitor on the status bar.
Posted: Wed Jul 26, 2023 8:44 am
by JSculley
Nope. You either have to select the sketch or the view to see any errors.
Have you considered an alternate approach? You can create a planar surface from your sketch in the model:
and then you don't need to convert entities at all in the drawing:
- image.png (5.13 KiB) Viewed 1884 times
Posted: Wed Jul 26, 2023 8:46 am
by Mike Gera
JSculley wrote: ↑Wed Jul 26, 2023 8:44 am
Thanks for the suggestion. Sounds interesting. I've never done anything with surfacing. How would I go about it?
Posted: Wed Jul 26, 2023 10:27 am
by JSculley
Mike Gera wrote: ↑Wed Jul 26, 2023 8:46 am
Create your sketch:
Then Insert...Surface...Planar (or use the command from the Surfaces toolbar):
- image.png (28.73 KiB) Viewed 1848 times
Posted: Wed Jul 26, 2023 10:37 am
by Mike Gera
JSculley wrote: ↑Wed Jul 26, 2023 10:27 am
Create your sketch:
That's probably better than what I'm currently doing, but I think I'd still have the same problem when it comes to construction lines.
Posted: Wed Jul 26, 2023 1:05 pm
by JSculley
Mike Gera wrote: ↑Wed Jul 26, 2023 10:37 am
Possibly. You should strive to eliminate sketch entities on drawings if at all possible. Perhaps if you could provide some detail on what you are trying to do that led you to this workflow, people will have ideas on a more robust and possibly better method.
Posted: Wed Jul 26, 2023 2:15 pm
JSculley wrote: ↑Wed Jul 26, 2023 1:05 pm
I agree. Even if you don't want to create a surface or solid body with the model sketch (though you usually should), doing the sketch in a model and inserting a drawing view of it in the Drawing is almost always a better choice than sketching directly in the Drawing.
Posted: Wed Jul 26, 2023 4:42 pm
by Mike Gera
Glenn Schroeder wrote: ↑Wed Jul 26, 2023 2:15 pm
I'm using SolidWorks to create an architectural floor plan.
Do I have AutoCAD? Yes. Could I use it? Yes.
I prefer the parametric, relation-driven sketching in SW, though, so I'm trying to make it work.
Posted: Wed Jul 26, 2023 5:52 pm
Mike Gera wrote: ↑Wed Jul 26, 2023 4:42 pm
I haven't done architectural plans, but I did once do a drawing of our offices to make a layout with the names, phone numbers, office numbers, etc. I still did it in a model, then imported that into the Drawing.
Posted: Wed Jul 26, 2023 7:38 pm
by Mike Gera
Glenn Schroeder wrote: ↑Wed Jul 26, 2023 5:52 pm
Glenn,
How exactly did you do that, if I may ask.
Posted: Thu Jul 27, 2023 8:28 am
I did it as an assembly. Everything is a solid. This is the same process I use for everything I model. I didn't see a need to reinvent the wheel to create the plan view of our shop.
Posted: Fri Jul 28, 2023 8:51 am
Mike Gera wrote: ↑Wed Jul 26, 2023 7:38 pm
Glenn,
Just like
@SPerman described above. In my case the walls were all a single Part file, but not a single sketch. I dislike complex sketches for several reasons.
Posted: Fri Jul 28, 2023 3:31 pm
Glenn Schroeder wrote: ↑Fri Jul 28, 2023 8:51 am
Just like @SPerman described above. In my case the walls were all a single Part file, but not a single sketch. I dislike complex sketches for several reasons.
Too many relations complicated the relationship....applies to CAD tools as well
