I Want to Add "Description" Column to the State Change Columns
Discuss SolidWorks PDM
DanBovinich
x 4
x 15
Unread post by DanBovinich »
When I want to change the state of a file, it would be helpful if, after the p/n column, there was the description column.
I see in the "Columns" section of the PDM admin program you can add another column set, but not modify the existing default column set. If I create a new column set, lets say we call it, "State Change 2", how can I re-direct PDM to use the new column set?
I'm using PDM SW2021.
Thank you for any help you may give me...
Thank you,
Dan B.
Answers: 54
x 7
x 815
Re: I Want to Add "Description" Column to the State Change Columns
You give permission to use the column set on a per group or per user basis, and use the 'Preferred' option to make it the default for a group or user, as explained in the PDM Help
DanBovinich
x 4
x 15
That worked! Thank you!
Dan
Thank you,
Dan B.
