Is there any way to have Solidworks automatically enter the name field when inserting an assembly constraint? Something similar to the "Enable on screen numeric input on entity creation" switch in system options for dimensioning?
I create a lot of LH/RH assembly constraints and it would be very helpful if I were automatically be in that field on creation.
Something like this would also be helpful for modeling, automatically be in the naming field when creating a feature!
Name assembly constraint on insert
- x 740
- x 897
Re: Name assembly constraint on insert
I don't think so.Bryan O wrote: ↑Fri Aug 11, 2023 9:54 am Is there any way to have Solidworks automatically enter the name field when inserting an assembly constraint? Something similar to the "Enable on screen numeric input on entity creation" switch in system options for dimensioning?
There is a "name feature on creation" checkbox in the feature manager area of the options, but that does not work on assembly mates.
However, to make things faster for you, you can change the visibility of the tree to
View Mates and Dependencies" Then, when you expand a component, the mates are shown instead of being inside a folder. Then, select the mate you want to rename and hit F2 to rename it (instead of slow double click, which I have disabled, because I hate it)
Thanks for the quick reply.
I currently use both of those for the same reason: forcing people to name there features in parts and (for assembly) to see mates that apply to the individual part. I really like the View mates command and it's visual isolation of related parts.
Here is a macro that will ask you for a name upon completion of the Mate command. SolidWorks only raises the notification at the completion of the command (when you hit the final checkmark and exit the Mate command). So if you add a whole bunch of mates at a time you'll have to remember what to name them afterward...
You should only have to run the macro once per session of SW.
- NameMatesOnCreation.swp
- (96 KiB) Downloaded 27 times
