Hey,
We'll be moving from 2019 to 2023 soon and I was wondering if there was any way to import keyboard shortcuts? The reason I ask is that we recreate our settings for every new version and each people have their own personnalized shortcuts. I know I can save the shortcuts to a text file, but how can I import them back? I'm sure there's a simple way.
Importing Shortcuts
- x 2191
- x 1892
Re: Importing Shortcuts
Short of having each one of them export their current settings with the save/restore settings tool, I'm not sure of an "easy" way.
- x 1652
- x 2058
I know some very knowledgeable people recommend starting everything from scratch with every new version, including user settings and document templates, but I never have. I still have stuff that's carried over from SW2009. Maybe if you use some type of PDM it's more critical?AlexLachance wrote: ↑Mon Aug 14, 2023 10:15 am Hey,
- x 2191
- x 1892
I've read a lot of people running into issues when restoring settings from a different version, especially if there are a couple of versions in between the setting's version and the actual version it is being applied to, which is why I recreate them.Glenn Schroeder wrote: ↑Mon Aug 14, 2023 10:52 am I know some very knowledgeable people recommend starting everything from scratch with every new version, including user settings and document templates, but I never have. I still have stuff that's carried over from SW2009. Maybe if you use some type of PDM it's more critical?
I also recreate every document templates because we've suffered from "File gotcha syndrome".
- x 1551
- x 1404
Use the Export/Import tool.
If there are problem importing everything, uncheck one at a time until to find the one has problem.
If I remember correctly, Menu Customize is the problem.
Do not export setting on first open of SW. First run of SW will create all the settings which won't save to registry until SW close.
So importing old settings at that time won't do any good either.
