Solidworks BSP Threads
terry1988
Unread post by terry1988 »
Hi, I am trying to use the thread feature on Solidworks and make a 3/4-inch tapped thread for a brass fitting. But only ever knowing the metric system It sucks. Can someone please let me know what the size to us in the dropdown feature? Currently using 0.7500-16 but that's wrong.
x 431
x 447
Re: Solidworks BSP Threads
acmall
x 30
Unread post by acmall »
Pipe threads are a bit different as 3/4" does not refer to the size of the thread but rather the size of the id of one particular grade of pipe. Different pipe grades have different wall thickness but the od remains the same so that the thread is the same. Always confuses the students here the first time they have to cerate a part with a BSP thread.
For BSPP threads with the hole wizard select DIN for Standard and Straight Pipe Tapped hole for Type. G3/4 will be 3/4 in BSP.
x 1636
x 1467
Frank_Oostendorp
x 184
x 229
Tapped does not equal tapered, so BSP isn't equal to NPT. ;)
x 1636
x 1467
Last time I got tapped was in a bar.
Not a British one.
I don't mind a British tap.
Maybe Irish is better.
