Hidden Lines in Drawing
MJuric
x 876
Unread post by MJuric »
What's the magic ticket that causes hidden lines to show up when you create a drawing using the API?
I created a quick macro to create a drawing and set "Hidden lines visible" when I recorded it and then when I ran it...no hidden lines.
I looked up a couple things and tried them and....no hidden lines.
Is there a way to do this?
Thank You
x 2314
x 1948
Re: Hidden Lines in Drawing
MJuric
x 876
SPerman wrote: Tue Sep 05, 2023 1:25 pm Does any of this help?
https://help.solidworks.com/2018/englis ... ple_vb.htm
I did mess with that a bit but my VBA skills are novice at best and it did not seem to work, or I could not get it to work. I also found a couple other places that had a few other suggestions but was also unsuccessful, again, most likely due to my lack of skills.
I will look at that again and see if it makes any more sense to me or I have any more luck, it is after all after the holiday :-)
x 25
x 561
Recording is useless about 80% of the time. It doesn't capture everything you do, and often the methods it uses are not the right thing if you're writing a macro.
What does your code look like now?
MJuric
x 876
josh wrote: Tue Sep 05, 2023 2:42 pm Recording is useless about 80% of the time. It doesn't capture everything you do, and often the methods it uses are not the right thing if you're writing a macro.
I completely agree but in my case, IE just learning and or just trying to get something done, it's a good "starting point".
josh wrote: Tue Sep 05, 2023 2:42 pm What does your code look like now?
To your eyes I'm sure a complete and utter disaster :-) I've attached the entire macro and the pasted the specific part for the drawings below.
Right now I have a macro that.
1) Opens and closes one of our large models, opens and closes it's drawing.
2) records the time
3) Re-Opens the large model. Rotates it as if you were using the arrow keys and then rotates it as if using a mouse. Then closes the model.
4) Records the time.
5) Opens a separate model, arrays the entire model, Closes it.
6) Records the time
7) Opens a part and arrays a feature in that part, closes it
8) Records the time
9) Opens a template, places three views and an ISO view (I wanted hidden lines on but it does not show them), closes the drawing
10) Records the time
...Done
This is the part that creates a drawing.
' New Document
swSheetWidth = 1.1176
swSheetHeight = 0.8636
Set Part = swApp.NewDocument("U:\Eng-Dept\SolidWorks Templates\TEMPLATES\E-SIZE (08_29_12).drwdot", 5, swSheetWidth, swSheetHeight)
Status = swApp.RunCommand(swCommands_e.swCommands_Comp_Display_Hiddenremoved, "")
Dim swDraw As SldWorks.DrawingDoc
Set swDrawing = Part
Set swDraw = swModel
Set swSheet = swDrawing.GetCurrentSheet()
swSheet.SetProperties2 12, 12, 1, 1, False, swSheetWidth, swSheetHeight, True
swSheet.SetTemplateName "\\Ame-server17\engineering2\Eng-Dept\SolidWorks Templates\AME E-Size INCH.slddrt"
swSheet.ReloadTemplate True
swApp.ActivateDoc2 "Draw3 - Sheet1", False, longstatus
Set Part = swApp.ActiveDoc
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
Set myView = Part.CreateDrawViewFromModelView3("C:\Temp\MacroTest\Models\AMS-600SR-01-3000_MT.SLDASM", "*Front", 0.218819956036135, 0.224195426336538, 0)
boolstatus = Part.ActivateView("Drawing View1")
boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
Set myView = Part.CreateUnfoldedViewAt3(0.218819956036135, 0.572584285932083, 0, False)
Part.ClearSelection2 True
boolstatus = Part.ActivateSheet("Sheet1")
boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0.30781648714777, 0.226366073436822, 0, False, 0, Nothing, 0)
Set myView = Part.CreateUnfoldedViewAt3(0.644266787691754, 0.224195426336538, 0, False)
boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0.283939369044648, 0.263267074141646, 0, False, 0, Nothing, 0)
Set myView = Part.CreateUnfoldedViewAt3(0.6882223914725, 0.693597861772903, 0, False)
boolstatus = Part.ActivateView("Drawing View2")
Set myView = Part.CreateSectionViewAt5(0.43479934251437, 0.571015877430554, 0, "A", 128, (excludedComponents), 0)
boolstatus = Part.ActivateView("Drawing View5")
' Save As
longstatus = Part.SaveAs3("C:\Temp\MacroTest\Models\AMS-600SR-01-3000_MT_Results.SLDDRW", 0, 0)
' Close Document
Set swDrawing = Nothing
Set Part = Nothing
swApp.CloseDoc "AMS-600SR-01-3000_MT_Results - Sheet1"
endTime = Timer
elapsedTime = endTime - startTime
xlSheet.Cells(2, 5) = elapsedTime
ActiveWorkbook.Save
xlApp.Workbooks.Close
xlApp.Quit
PerformanceTest.swp
(120 KiB) Downloaded 230 times
x 2314
x 1948
I would try adding this
swDraw.ViewDisplayHidden
after
MJuric
x 876
SPerman wrote: Tue Sep 05, 2023 3:56 pm I would try adding this
after
I've not tried this in my full macro but I tried it in my "Small chunk I worked on to do this part" and I get... I can try it in the full version but it takes ~30 minutes to run so I try to do it in a smaller bit.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
' New Document
Dim swSheetWidth As Double
Dim swSheetHeight As Double
Dim swDrawing As DrawingDoc
Dim swSheet As sheet
Dim myModelView As Object
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
Dim myView As Object
Dim excludedComponents As Variant
' Save As
x 25
x 561
So you have a few lines here that say "Set myView = "....
After this point, myView is a direct reference to that drawing view that gets created. Well, at least it is until later when you say "Set myView ="... something different.
So myView is a View object, so you can use all the properties and methods of the View object on it. One of the Methods of the View is "SetDisplayMode4". The proper arguments for this method are shown in the help, along with an example.
x 2314
x 1948
Maybe it needs parenthesis on the end? Hopefully one of the macro guru's will chime in. Clearly I'm just speculating.
x 25
x 561
SPerman wrote: Tue Sep 05, 2023 4:36 pm Maybe it needs parenthesis on the end? Hopefully one of the macro guru's will chime in. Clearly I'm just speculating.
Well... The main reason it was failing is that swModel is never set to anything. Therefore the swModel is the empty object variable value of Nothing. Therefore, "Set swDraw = swModel" sets swDraw equal to Nothing. This is totally valid code-wise until you get to the line where you actually ask swDraw to do something - swDraw.ViewDisplayHidden. Since swDraw references Nothing, and Nothing doesn't have the method ViewDisplayHidden, that's the line that gets an error.
