Angled dimension from vertice
x 2361
x 2011
Hey,
I know I can do angled dimensions from a vertice but I'm unable to achieve it. Could somone please enlighten me..? The toggle switch just doesn't show up upon selection.
From memory, I'm supposed to select the line and the vertice but I can't seem to get it to work.
by JSculley » Wed Sep 06, 2023 11:20 am
Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Officially known as Creating Angular Dimensions Using an Imaginary Line
x 220
Re: Angled dimension from vertice
Unread post by Dwight »
I believe it's either 2 edges or 3 points.
x 2361
x 2011
Dwight wrote: Wed Sep 06, 2023 11:14 am I believe it's either 2 edges or 3 points.
There was a new thing added which allowed to select a point and then a round blue thing would would appear split in quarters next to the mouse. That's the thing I'm refering to, I just can't find it :lol:
x 877
x 2361
x 2011
JSculley wrote: Wed Sep 06, 2023 11:20 am Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Hrmm.. Doesn't seem to work in 2023 SP3..?
Ronan
x 38
x 10
Unread post by Ronan »
Just tried it on 2023 sp3. Works ok for me. Never knew this before. Nice feature.
x 810
x 978
As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
x 877
AlexLachance wrote: Wed Sep 06, 2023 11:33 am Hrmm.. Doesn't seem to work in 2023 SP3..?
Are you in a detail view in a drawing? There is a bug report against SW2023 SP3:
BR10000357494 -- Cannot dimension to imaginary lines in detail view
x 2361
x 2011
JSculley wrote: Wed Sep 06, 2023 12:26 pm Are you in a detail view in a drawing? There is a bug report against SW2023 SP3:
Ugh, it was appearing misplaced because of a trimmed view... I'm feeling stupid now :lol:
Krzysztof Szpakowski
x 58
x 75
DanPihlaja wrote: Wed Sep 06, 2023 12:03 pm As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
The point must lie on a line or its extension (colinear)
Hmm... A alien doesn't know...
I'm starting to have doubts...
x 810
x 978
Krzysztof Szpakowski wrote: Fri Sep 08, 2023 1:48 pm The point must lie on a line or its extension (colinear)
I don't understand what you are trying to say here....
