Simulation not running
For some reason when I run the simulation, the load is not acting on the cantilever. Can somebody point me in the right direction?
- x 37
- x 95
Re: Simulation not running
Try a pack 'n go on the part. Hopefully that will include the simulation and would allow us to look at what you're doing.
- x 2373
- x 2015
You seem to be lacking elements inside your study.
Your body has been set to rigid, which means it will not deform. A deformable body has the circled icon and gives the results like this:
A body set to rigid has the circled icon and results like yours:
To correct the problem, right click the body in the tree and select 'Make deformable':
