Show Your Work
Show Your Work
In the other place one of my favorite threads was the place where people showed images of their projects. I've got more, but this is good for now.
- Craig Makarowski
- x 7
- x 73
Re: Show Your Work
Portable Equipment stand designed in Solidworks 2018 and Rendered in side UNREAL engine 4.25
- x 2361
- x 2011
- x 810
- x 978
Re: Show Your Work
Here is my latest large project (with the customer part hidden):
This was designed using the master model technique (with a smattering of SSP in there)
This is an electro-chemical deburr fixture for deburring the areas where holes cross inside the part (areas that are really hard to get to by hand)
If the customer part were shown, it would be inside this space:
Re: Show Your Work
They are control grips.AlexLachance wrote: ↑Fri Mar 26, 2021 7:52 am
Excuse my ignorance, but what is it supposed to be..? a 3D Scanner?
Re: Show Your Work
My best disaster! Great design work and a great team overcoming great challenges, torpedoed at the 11th hour by an overzealous founder with an itchy trigger finger.
- x 1758
- x 2129
Re: Show Your Work
I watched the whole thing. It sounds like a great product.
Re: Show Your Work
Had potential to be a decent product. Instead it turned into a great story.
- x 1758
- x 2129
Re: Show Your Work
Here's some of my work. I helped with designing this installation, and the modeling and drawing were all mine.
- Craig Makarowski
- x 7
- x 73
Re: Show Your Work
here are a few of my latest projects designed in SolidWorks and rendered in Unreal 5
- x 1636
- x 1467
Re: Show Your Work
https://westernmechanical.net/projects/ ... e.php?id=4
I designed the hydraulic cylinder. With some FEA to make sure thread will hold and cap and gland won't blow out.
- x 1636
- x 1467
Re: Show Your Work
Can't believe the building is still there.
Add catwalk around the sign.
- x 1231
Re: Show Your Work
Current project: 44 ft firewood conveyor- modular construction, high-way towable, hydraulic lift, radial drive wheels to pile high and wide, optional radio controls for processor or loader operator.
- x 2361
- x 2011
Re: Show Your Work
Took a SW and Key Shot class here at ASU, made all the solids with SW, here are some of the results.
learn alot about how much I do not know about photos
- Jaylin Hochstetler
- x 380
- x 355
Re: Show Your Work
Wow! That's awesome! It's crazy what you can do with CAD/rendering. Such as https://grabcad.com/library/ram-trx-1
Re: Show Your Work
that is way above my paygrade.Jaylin Hochstetler wrote: ↑Thu Sep 22, 2022 5:28 pm Wow! That's awesome! It's crazy what you can do with CAD/rendering. Such as https://grabcad.com/library/ram-trx-1
Download all the things you want from GrabCAD now, it is being killed off June 2023, they've said they will "CONTROL ALT-DELETE"
Re: Show Your Work
I believe it is only GrabCAD workbench that is being removed in June 2023.
