2 questions:
1) It seems like when I suppress a part the mates do not necessarily suppress with it.
Is there a switch that will allow SW to suppress all the mates of a part when I suppress the part?
2) When in assembly, I would like to see (highlight) the location of a part in the Asm/SUB Asm in the feature manager when I select it in the graphics area.
It currently only takes me to the top level of the Asm/Sub Asm.
Assembly mates and Parts highlights
- x 2480
- x 2099
Re: Assembly mates and Parts highlights
1) I believe there is but I can't find it in my settings
2)
2)
Thanks Alex,AlexLachance wrote: ↑Thu Sep 21, 2023 12:39 pm 1) I believe there is but I can't find it in my settings
A coworker found this. Turning this switch on expands the subasm tree and highlights the component. Still looking for a solution to suppress the mates with a component suppression.
- x 2480
- x 2099
Hey mate(see what I did there), check this out
There's a guy that says it's a bug that has to do with files from previous versions. Maybe you could check and see if all your files are in the current version using the performance evaluation tool.
- x 821
- x 1008
1) Did you recently switch to SW 2022 SP2? If so, upgrade to SP3 at least. I have read that this is a specific bug with SP2 and legacy assemblies.
2)
Edit: Aaaand I realized that just said all the exact things that @AlexLachance said. LOL
Great minds think alike and all that.
2)
