OpenGL in standalone App?
JeromeP
Unread post by JeromeP »
Hello, I'm creating a VB.net application to insert OpenGL objects in my model space.
Doing it with an add-in works great like this example from Artem:
https://www.codestack.net/solidworks-ap ... trahedron/
But I can't make it work on a standalone application with the OnBufferSwapNotify event.
The event fires but nothing is drawn and after awhile it crashes with 'AccessViolationException:Attempted to read or write protected memory'.
Is it even possible to do? Do I need to use an other method?
Here is the strip-down code that I use:
Imports SolidWorks.Interop.sldworks
Module SolidWorksFunctions
    Private swApp As SldWorks
    Private swModel As ModelDoc2
    Private swView As ModelView
    Public Sub SwIni()
        swApp = GetObject(Nothing, "SldWorks.Application")
        swModel = swApp.ActiveDoc
        If swModel Is Nothing Then Exit Sub
        swView = swModel.ActiveView
        AddHandler swView.BufferSwapNotify, AddressOf OnBufferSwapNotify
    Private Function OnBufferSwapNotify() As Integer
        Console.WriteLine("OnBufferSwapNotify")
        Dim a() As Double = {0, 0, 0}
        Dim b() As Double = {1, 0, 0}
        Dim c() As Double = {0.5, Math.Sqrt(3) / 2, 0}
        Dim d() As Double = {0.5, Math.Sqrt(3) / 6, Math.Sqrt(6) / 3}
        DrawTriangle(a, c, b, Color.Green, True, False, False, 3.0F)
        DrawTriangle(a, d, c, Color.Green, True, False, False, 3.0F)
        DrawTriangle(c, d, b, Color.Green, True, False, False, 3.0F)
        DrawTriangle(d, a, b, Color.Green, True, False, False, 3.0F)
        Return 0
    End Function
    Private Sub DrawTriangle(a() As Double, b() As Double, c() As Double, color As Color, fill As Boolean, wireframe As Boolean, dashed As Boolean, width As Single)
        OpenGl.glPolygonMode(OpenGl.GL_FRONT_AND_BACK, IIf(fill, OpenGl.GL_FILL, OpenGl.GL_LINE))
        OpenGl.glDisable(OpenGl.GL_LIGHTING)
        If wireframe Then
            OpenGl.glEnable(OpenGl.GL_LINE_SMOOTH)
            If dashed Then
                OpenGl.glEnable(OpenGl.GL_LINE_STIPPLE)
                OpenGl.glLineStipple(4, &HAAAA)
        OpenGl.glBegin(IIf(wireframe, opengl.GL_LINE_LOOP, opengl.GL_TRIANGLES))
        If wireframe Then OpenGl.glLineWidth(width)
        OpenGl.glColor4f(color.R / 255.0F, color.G / 255.0F, color.B / 255.0F, color.A / 255.0F)
        opengl.glVertex3d(a(0), a(1), a(2))
        opengl.glVertex3d(b(0), b(1), b(2))
        opengl.glVertex3d(c(0), c(1), c(2))
        OpenGl.glEnd()
        OpenGl.glDisable(opengl.GL_LINE_SMOOTH)
        opengl.glDisable(opengl.GL_LINE_STIPPLE)
End Module
x 1659
x 1498
Re: OpenGL in standalone App?
Addin and macro are running in Solidwork's process and memory space.
Standalone is not. So Windows see Standalone try to modify Solidwork's memory.
Usually Standalone is to do things without openning or interacting with the program, SW or IV or Excel.
