save a sheet metal part as a .dwg there is a prefix "flat pattern" that shows up all the time
When I save a sheet metal part as a .dwg there is a prefix "flat pattern" that shows up all the time? Is there a way to remove this? Just time consuming to remove every time.
- x 1214
- x 1999
Re: save a sheet metal part as a .dwg there is a prefix "flat pattern" that shows up all the time
OOTB no. You might try a macro.....then you could have it name the file whatever you want.
This may be overkill:
viewtopic.php?p=14464&hilit=dxf+dwg#p14464
Create a drawing with the flat pattern view and save that as your DWG file. You can delete all the title block so your DWG file will only have the flat view and bend lines/notes
