Changing sheet metal "Auto Relief" is having no affect on part
Posted: Fri Oct 27, 2023 1:27 pm
by Mike Gera
The fabrication department told me that the corners of the attached part need additional relief.
I had Auto Relief set to Tear. I tried changing it to Obround (0.5). It had no effect on the Flat Pattern.
I then tried Rectangular (0.5). That had no effect on the flat pattern.
I then tried different numeric values with Obround and Tear. They had no effect.
Am I doing something wrong?
Thanks for any replies.
Re: Changing sheet metal "Auto Relief" is having no affect on part
Posted: Fri Oct 27, 2023 2:00 pm
by TTevolve
because you manually did the cut in the corners it won't change when you use the convert to sheet metal. You can change the cut you made to make it larger.
Or don't do those corner cuts at all. After your shell operation do the "convert to sheet metal" operation, pick the bottom surface and then add all the bends, use the tear vales there to control the corner relief.
Posted: Fri Oct 27, 2023 2:05 pm
by TTevolve
Better yet, I would not have even done the shell, I would have just extruded the bottom your 0.135 thickness and then added edge flages.
Posted: Sat Oct 28, 2023 1:33 am
Got rid of the shell and corner cuts, use convert to sheet metal, which rips the corners. Last add the corner reliefs.
Posted: Sat Oct 28, 2023 8:26 am
by Mike Gera
Thank you, all. It's quite obvious now what I did. Some good advice here.
I'll work with this.
Posted: Sat Oct 28, 2023 8:31 am
by Mike Gera
Obviously not directly related, but what is the purpose of the double duplicated vertical feature tree? I never understood that.
Posted: Sat Oct 28, 2023 11:40 pm
Mike Gera wrote: ↑Sat Oct 28, 2023 8:31 am
We deal with a lot of configurations so I often split the tree to show configs below.
Posted: Mon Oct 30, 2023 9:29 am
by Mike Gera
@jcapriotti
On mine, the lower feature tree seems to mirror the upper. How would I use one in a different manner than the other?
Posted: Mon Oct 30, 2023 2:29 pm
Mike Gera wrote: ↑Mon Oct 30, 2023 9:29 am
@jcapriotti
It defaults to the Feature Manager tree....just select a different tab like the Config manager.
Posted: Mon Oct 30, 2023 3:50 pm
That drives me insane. I'm sure there is some situation where it might be helpful, but it hasn't found its way into my workflow.
Posted: Mon Oct 30, 2023 3:55 pm
by Mike Gera
SPerman wrote: ↑Mon Oct 30, 2023 3:50 pm
It would be nice if it could be disabled.
Posted: Mon Oct 30, 2023 4:15 pm
It is the default UI when working in Simulation. One window shows cad, the other simulation. Neither are big enough to be very useful, so it is a constant struggle of scrolling in one window or another, and constantly adjusting the window split position to so that it is easier to find what you are looking for.
