add "in²" to end of info written by this macro code
mraycii
x 3
Unread post by mraycii »
Let me preface this by saying I am a complete novice to writing code.
I have acquired some code that almost does exactly what I need done. I need it tweaked a bit to do the following:
Make the value that is written have " in²" added to the end of it.
Thanks in advance for your expertise and help.
The attached image shows the way the value is written using the code below.
Here is the code:
Const CONF_SPEC_PRP As Boolean = False
Const COPY_RES_VAL As Boolean = True
Dim PROPERTIES As Variant
Sub Init(Optional dummy As Variant = Empty)
PROPERTIES = Array("Bounding Box Area-Blank") 'list of custom properties to copy or Empty to copy all
try_:
On Error GoTo catch_
Init
Set swModel = swApp.ActiveDoc
Dim swCutListPrpMgr As SldWorks.CustomPropertyManager
Set swCutListPrpMgr = GetCutListPropertyManager(swModel)
If Not swCutListPrpMgr Is Nothing Then
Dim swTargetPrpMgr As SldWorks.CustomPropertyManager
If CONF_SPEC_PRP Then
Set swTargetPrpMgr = swModel.ConfigurationManager.ActiveConfiguration.CustomPropertyManager
Else
Set swTargetPrpMgr = swModel.Extension.CustomPropertyManager("")
CopyProperties swCutListPrpMgr, swTargetPrpMgr, PROPERTIES
Else
Err.Raise vbError, "", "Cut-list is not found"
GoTo finally_
catch_:
swApp.SendMsgToUser2 Err.Description, swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
finally_:
Function GetCutListPropertyManager(model As SldWorks.ModelDoc2) As SldWorks.CustomPropertyManager
Set swFeat = model.FirstFeature
While Not swFeat Is Nothing
If swFeat.GetTypeName2() = "CutListFolder" Then
Set GetCutListPropertyManager = swFeat.CustomPropertyManager
Exit Function
Wend
End Function
Sub CopyProperties(srcPrpMgr As SldWorks.CustomPropertyManager, targPrpMgr As SldWorks.CustomPropertyManager, vPrpNames As Variant)
If IsEmpty(vPrpNames) Then
vPrpNames = srcPrpMgr.GetNames()
If Not IsEmpty(vPrpNames) Then
For i = 0 To UBound(vPrpNames)
prpName = vPrpNames(i)
Dim prpVal As String
Dim prpResVal As String
srcPrpMgr.Get5 prpName, False, prpVal, prpResVal, False
Dim targVal As String
targVal = IIf(COPY_RES_VAL, prpResVal, prpVal)
targPrpMgr.Add2 prpName, swCustomInfoType_e.swCustomInfoText, targVal
targPrpMgr.Set prpName, targVal
Next
Else
Err.Raise vbError, "", "No properties to copy"
by SPerman » Tue Nov 07, 2023 11:10 am
This will append " in2" to your string. I can't help with formatting the 2 to a superscript.
targVal=targVal+" in2"
Answers: 13
x 2018
x 1689
Re: add "in²" to end of info written by this macro code
mraycii
x 3
Appreciate your help. I need to know exactly where to place this in the current macro. Thanks again.
Answers: 13
x 2018
x 1689
The first two lines are from your macro. Place the new 3rd line after
mraycii
x 3
Never mind, I figured it out.
Thanks for your help.
