STEP file
Posted: Fri Nov 17, 2023 3:23 pm
by Qtvela
Hi!
I have a STEP model to work with. It is cylinder with debossed texture around it, what I want to do is emboss same texture. I`m trying to direct edit, selecting face that I want to emboss, move face/offset, typing in distance and after clicking enter - it gives me an error. Probably because, as I mentioned before texture is wraped around the model and offset is not going one direction.
Sorry for bad english, hope you understand what I`m asking.
Thanks in advance.
Re: STEP file
Posted: Sat Nov 18, 2023 12:00 pm
by zxys001
Hello Otvela, what you could try is Surface Offset Copy either the debossed faces and Thicken or copy the surrounding cylinder faces and Cut Thicken.
Re: STEP file
Posted: Mon Nov 20, 2023 7:11 am
by DanPihlaja
Qtvela wrote: Fri Nov 17, 2023 3:23 pm Hi!
Thanks in advance.
If you could share the part, a lot of users here can show you how to do it.
