Folder Cache options
Discuss SolidWorks PDM
MMartens
Answers: 5
x 6
Unread post by MMartens »
I have my application settings folders set to Refresh the cache during login. But, there is 1 subfolder in the structure that I don't want to Refresh because the size of the files are so large (we keep past versions of the Inventor content center libraries in there and they are quite large). I have the subfolder set to clear the cache on logout and unchecked the Refresh option but it still gets the latest version of the files on login.
Any suggestions?
Answers: 24
x 242
x 387
Re: Folder Cache options
If you're caching a folder, then you can't specify a sub-folder to ignore. If you want to exclude it, you'll have to select only the other sub-folders to cache at login.
