I have a sheet metal spiral and need to get it flattened. Can you help me? Is it possible to flatten?
How to flatten a spiral
- Tapani Sjöman
- x 33
- x 14
- Spiral.SLDPRT
- (188.35 KiB) Downloaded 65 times
Re: How to flatten a spiral
Could you create the part using the flex command?
https://help.solidworks.com/2023/englis ... Redirect=1
Yes but you need to use a different method to model it (check following videos) or use surface flatten tool (you need to have SW premium version).
- Tapani Sjöman
- x 33
- x 14
Thank you for your messages! I have never done Flex and don't know if I can make it.
Lofted Bends might be an option, but need to play a bit with it. Not sure if it works for many round helix thoug.
Yes, Lofted bend looks working!
