Reset Light Sources
Library for macros
Stefan Sterk
x 43
x 62
Reset Light Sources
Unread post by Stefan Sterk »
Here is a simple macro which gives you the power to easily reset your light sources within a SOLIDWORKS Part or Assembly model by deleting the current light sources and adding back the 'default' (user specified) light sources.
Option Explicit
    Dim swModelDocExt As SldWorks.ModelDocExtension
    ' Get SolidWorks Application
    ' Get active model document
    Set swModel = swApp.ActiveDoc
    ' Check for active document and if document is a Assembly or Part
    If swModel Is Nothing Then End
    If swModel.GetType <> swDocASSEMBLY And swModel.GetType <> swDocPART Then End
    Set swModelDocExt = swModel.Extension
    ' Delete current lights
    DeleleteLights swModel
    ' Add a directional light source
    SetAmbiantLightSource swModel, True, RGB(255, 255, 255), 0.3
    AddDirectionalLight swModel, "Directional1", True, RGB(255, 255, 255), 0.1, 0.3, 0.3, True, 90, 45
    AddDirectionalLight swModel, "Directional2", True, RGB(255, 255, 255), 0, 0.1, 0.3, True, -154.41, 37.77
    AddDirectionalLight swModel, "Directional3", True, RGB(255, 255, 255), 0, 0.2, 0.3, True, -101.07, 19.94
    ' Rebuild model to show light
    swModelDocExt.EditRebuildAll
Function DeleleteLights(swModel As SldWorks.ModelDoc2)
    Dim i As Integer
    For i = swModel.GetLightSourceCount - 1 To 0 Step -1
        swModel.DeleteLightSource i
    Next i
End Function
Function AddDirectionalLight( _
    swModel As SldWorks.ModelDoc2, _
    LightName As String, _
    OnInSolidWorks As Boolean, _
    Color As Long, _
    Ambient As Double, _
    Brightness As Double, _
    Specularity As Double, _
    LockToModel As Boolean, _
    Longitude As Double, _
    Latitude As Double _
    Dim X As Double, Y As Double, Z As Double
    GetCartesianCoordinates Longitude, Latitude, X, Y, Z
    swModel.AddLightSource LightName, 4, LightName
    swModel.SetLightSourcePropertyValuesVB LightName, 4, Brightness, Color, 1, X, Y, Z, 0, 0, 0, 0, 0, 0, 0, Ambient, Specularity, 0, Not OnInSolidWorks
    swModel.LockLightToModel swModel.GetLightSourceCount - 1, LockToModel
End Function
Function GetCartesianCoordinates(ByVal Longitude As Double, ByVal Latitude As Double, ByRef X As Double, ByRef Y As Double, ByRef Z As Double)
    Longitude = (Longitude * (3.14159265359 / 180))
    Latitude = (Latitude * (3.14159265359 / 180))
    X = Cos(Latitude) * Sin(Longitude)
    Z = Cos(Latitude) * Cos(Longitude)
    Y = Sin(Latitude)
End Function
Function SetAmbiantLightSource(swModel As SldWorks.ModelDoc2, OnInSolidWorks As Boolean, Color As Long, Ambient As Double)
    swModel.SetLightSourcePropertyValuesVB swModel.GetLightSourceName(0), 1, 0, Color, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Ambient, 0, 0, Not OnInSolidWorks
End Function
Answers: 13
x 2023
x 1691
Re: Reset Light Sources
Thank you. I was just going to start asking about / looking for such a macro. oa
loeb
x 35
x 8
Unread post by loeb »
I wrote a similar one that deletes all lights and sets ambient to 1. Now all our parts that are the same material look the same.
Answers: 13
x 2023
x 1691
I find 1 to be a bit too bright, but I am doing the same thing.
