Hiding Context toolbar
JeromeP
Unread post by JeromeP »
Is there an API command to hide or disable the context toolbar (the one that appears when right clicking on a face) for parts?
x 25
x 561
Re: Hiding Context toolbar
Do you mean an API command to change the setting under Tools-Customize such that it doesn't appear, or a command to dismiss it if it's currently shown on screen?
JeromeP
Correct me if I'm wrong, but I don't think this menu has a setting in Tool>Customize so it doesn't appear.
But if there is, either way would be great.
I've found this link that can be used to hide the menu specific to the selection,
but there is still a menu that appears on right click (the one on the right on the above picture)
https://help.solidworks.com/2022/englis ... ple_vb.htm
I guess I could use an event like doc_UserSelectionPostNotify
to do a SendKeys "{ESC}" but that's a bit clunky
x 893
Why would you want to do that? What are you actually trying to accomplish?
JeromeP
I'm working on a macro feature that display custom information in OpenGL,
and can be used to interact in a specific manner with the mouse.
But this menu is in the way.
I would like to disable it while the macro feature is in edit mode.
JeromeP
I've manage to block the right click command, and thus the menu, with the InputHelper library. https://github.com/Visual-Vincent/InputHelper
Although I would love to learn a better way to do it with Solidworks commands.
Private Sub MouseHook_MouseDown(sender As Object, e As InputHelper.EventArgs.MouseHookEventArgs) Handles MouseHook.MouseDown
	If e.Button = MouseButtons.Right Then e.Block = True
x 25
x 561
Pretty sure SW doesn't have any way to block right-clicks.
Did you even look at Tools-Customize?
JeromeP
Yeah. I've tried all those ones. That doesn't do it.
No worries, InputHelper does the job.
