"hidden" lines showing with hidden lines removed
Posted: Tue Jan 09, 2024 1:16 pm
by Mike Gera
In the view below, the elliptical line indicated with the red arrow should not be showing.
FWIW, the view is set to "hidden lines removed"
Any idea what could be causing this?
Note that a similar thing is happening at the top of item #6.
Thanks for any help.
Re: "hidden" lines showing with hidden lines removed
Posted: Tue Jan 09, 2024 1:47 pm
Cosmetic threads and/or surfacic bodies could do something like this.
Posted: Tue Jan 09, 2024 2:00 pm
by Mike Gera
AlexLachance wrote: Tue Jan 09, 2024 1:47 pm Cosmetic threads and/or surfacic bodies could do something like this.
Thanks. Where can they be turned off?
Posted: Tue Jan 09, 2024 2:05 pm
by DanPihlaja
Mike Gera wrote: Tue Jan 09, 2024 2:00 pm Thanks. Where can they be turned off?
One way is to set your cosmetic threads to high quality. For some reason, draft quality makes them shine through.
Another way is to hide them at the part level.
Posted: Tue Jan 09, 2024 2:16 pm
Try turning off annotations.
Try turning off annotations. That is what controls that being displayed in modelling. I assume it does the same in drafting. (I can't test it now, due to power outage from storms.)
Posted: Tue Jan 09, 2024 2:21 pm
by Mike Gera
DanPihlaja wrote: Tue Jan 09, 2024 2:05 pm image.png
1. Cosmetic threads are already turned off and/or are non-existent.
2. Cosmetic thread display is already set to high quality.
Posted: Tue Jan 09, 2024 2:38 pm
by Mike Gera
SPerman wrote: Tue Jan 09, 2024 2:16 pm Try turning off annotations. That is what controls that being displayed in modelling. I assume it does the same in drafting. (I can't test it now, due to power outage from storms.)
No luck there.
Posted: Tue Jan 09, 2024 2:48 pm
Does anything here help?
https://help.solidworks.com/2021/englis ... hreads.htm
"The visibility of cosmetic threads follows the visibility of the parent feature. When you change display mode, add features to the Show Hidden Edges list, or hide a component, the visibility of cosmetic threads changes automatically."
There is also "old vs. new" cosmetic threads.
https://www.goengineer.com/blog/solidwo ... d-upgrades
Posted: Tue Jan 09, 2024 2:49 pm
One more link with good info. I still think this is controlled by annotations.
https://www.cati.com/blog/solidworks-wh ... c-threads/
Posted: Tue Jan 09, 2024 3:30 pm
Mike Gera wrote: Tue Jan 09, 2024 2:38 pm No luck there.
Maybe a sketch showing up? Have you tried switching display states on the view? Is it viewable inside the model?
Posted: Tue Jan 09, 2024 6:08 pm
This is what changes it for me. 2022 SP5. (Finally got power back on.)
Posted: Wed Jan 10, 2024 8:20 am
by Mike Gera
I've tried all the suggestions in this thread (much appreciative of all of them). Nothing seems to work.
I did notice that if I open one of the suspect .SLDPRT files and rebuild it, then go back into the .SLDDRW, the undesired lines disappear...until I pan. I'm going to declare this one a bug or a graphics card glitch. (Nvidia Quadro RDX5000)
Posted: Wed Jan 10, 2024 8:21 am
by Mike Gera
By the way, has anyone noticed that this forum is very slow (as in load speeds, post speeds, etc.)?
Posted: Wed Jan 10, 2024 8:46 am
Mike Gera wrote: Wed Jan 10, 2024 8:21 am By the way, has anyone noticed that this forum is very slow (as in load speeds, post speeds, etc.)?
See viewtopic.php?p=33272#p33272
