Hi all,
I have run a comparison analysis on a bolted connection with two plates in shear. The first used bolts with tight fit, the second used pins. Comparing the connector results, the pin shear is about 43% higher than the bolts in this analysis. I've noticed also than on a magnified (20x) displacement scale there is slight relative movement between the plates in the bolted connection, whereas there is none in the pinned. I can only guess that the bolt formulation is different to the pinned formulation and therefore allows this movement. Any ideas?
- Board index CAD SolidWorks SW Simulation
- Search
- It is currently Thu Nov 21, 2024 4:26 am
- All times are UTC-05:00
Shear force result - pin vs bolt connector
Jump to
- Welcome New Members
- ↳ Welcome
- ↳ Forum Rules
- CAD
- ↳ CAD Agnostic
- ↳ SolidWorks
- ↳ How To Questions
- ↳ SW General
- ↳ SolidWorks FAQ
- ↳ API
- ↳ Macro Library
- ↳ SolidWorks PDM
- ↳ 2D Drawings
- ↳ Routing-Electrical-Piping
- ↳ Surfacing
- ↳ SW Simulation
- ↳ SW Motion Analysis
- ↳ Enhancement Requests
- ↳ Solid Edge
- ↳ NX
- ↳ Onshape
- ↳ Creo
- ↳ Inventor
- ↳ Fusion 360
- ↳ KeyCreator
- ↳ Catia and 3DX
- ↳ IronCAD (CAXA)
- ↳ Shapr3D
- ↳ subD and Mesh
- ↳ Hardware
- ↳ Misc CAD
- ↳ Draftsight
- Other Technology
- ↳ Rendering and Motion
- ↳ 3D Scan
- ↳ AI and Related Tech
- Manufacturing
- ↳ 3D Print
- ↳ CAM
- ↳ Robotics
- Board Business
- ↳ Suggestions
- ↳ What's Wrong?
- ↳ What's New
- ↳ Events
- ↳ Media and Advertising
- Off Topic
- ↳ Kitty Dump
- ↳ Job Listings
- ↳ For Sale and Want To Buy
