Oddball text question
Library for macros
doobes
x 8
x 60
Unread post by doobes »
So for reasons I cannot explain, I've wound up with paper copies of some VBA code that I want to use.
I've gone through a scanning process and corresponding OCR, (all on a Linux box, BTW) which works pretty well....
but, and there is always a but;
Some of the text is obviously OCR'ed in a non-standard text encoding.
I've imported it into the VBA IDE and the odd line simply will not run.
If I type the exact same line, character by character, it will run, thus the encoding conclusion.
Any thoughts as to a process to run through to ensure the text encoding is the one that the VBA IDE wants to see?
I tried changing the encoding to ANSI in Notepad++ but that had no effect.
Thanks for any thoughts.
chris
x 383
x 414
Re: Oddball text question
I have seen issues with the double quotes using similar process, so I type them and then all is good. So, check if this is the case with your line.
ryan-feeley
x 88
Unread post by ryan-feeley »
I expect @gupta9665 is on to something with the quotations.
Be careful on ANSI (8 bits) v ASCII (7 bits). They overlap on the first 128 characters, but ANSI has another 100 or so odd-balls. These include a few variations on quotation marks and other stuff that isn't on a typical keyboard. I could easily see your scanner picking something obscure. I'd try again with ASCII encoding and see if that works.
Answers: 54
x 7
x 809
What OCR software are you using on the Linux machine?
Also, can you upload one of the misbehaving files?
doobes
x 8
x 60
ryan-feeley wrote: Sun Feb 18, 2024 1:13 pm I expect @gupta9665 is on to something with the quotations.
Bingo
I'm using OCRFeeder - https://wiki.gnome.org/Apps/OCRFeeder
Switching to ANSI via Notepad++ converted some of the quotation marks into weird characters.
Thank you!
chris
