Is it possible to lengthen the reference line of a weld note?
Yes, it can effectively be done by adding a jog point, but I prefer not to do it this way.
Please see the image below. (I did this in AutoCAD.)
Is this possible?
Thanks.
You can right click on it's arrow and add a jog point and then set it parralel to the other and have it the desired length
Go to full postSW 2022 SP 5.0
Windows 11
Windows 11
- x 2158
- x 1847
Re: Is it possible to lengthen the reference line of a weld note?
Hi Alex.AlexLachance wrote: ↑Wed Feb 21, 2024 9:35 am You can right click on it's arrow and add a junction and then set it parralel to the other and have it the desired length
Do you mean a "jog point"? I do not see an option for "junction".
Also, how would I lock it parallel?
Thanks.
SW 2022 SP 5.0
Windows 11
Windows 11
- x 2158
- x 1847
It's hokey, but you can add spaces before/after the weld size value and/or weld length-pitch values:
The downside is that when you go back into the weld symbol editor, it may look like there is no value:
- x 2158
- x 1847
Thanks for that alternative, less "annoying" then having to move the jog point each time the dimension is moved.
Gotcha.AlexLachance wrote: ↑Wed Feb 21, 2024 10:00 am Most likely, yeah! In french it's "Jonction" which can translate to both jog point and junction depending.
I was hoping for less of a workaround solution, but this works. I can "snap" the line parallel. It doesn't lock in place, but at least it's truly parallel.
Thanks, as always.
SW 2022 SP 5.0
Windows 11
Windows 11
I had thought about that but shied away, partially for the reason you mentioned.
SW 2022 SP 5.0
Windows 11
Windows 11
